igniter comes on flame comes on for about 15 seconds then igniter clicks off along with flame and then no heat rest of cycle
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
dryer exhaust vent is fine diconnected hose and samething happens. igniter glow red gas turns on then flame for aboit 15 seconds than everything clicks off
Originally Posted by: Gene  ...Would the igniter glow again or not?... Did I miss the answer? Gene.
Originally Posted by: Gene  Did I miss the answer?
Gene. Have Maytag Dryer Model #MDG4806AWW with no heat. Dryer igniter glows flame comes on for about 15 seconds and shuts off. Dryer vent is free of lint,tested everything for continuity is ok, I think its the gas valve. This model you can't just replace the coils. How do I replace the whole assembly. Thanks Rick
Originally Posted by: rjboy  ...This model you can't just replace the coils... Hi Rick, Why do you think you can't? Yes you can. Just try the coil kit Part number: 279834
Replace coils and iginiter glows red,flame comes on for 15 seconds and clicks off. duct isn't clogged, tested everything else for continuity and check out ok. What else can it be? Maytag Dryer model # MDG4806AWW
Check out the blower wheel. Make sure it's not slipping at the motor shaft. If there is nothing wrong, replace the hi-limit thermostat (#10 at the diagram). - The blower wheel Part number: 56000
