rjboy
#1 Posted : Tuesday, October 30, 2012 5:50:32 AM(UTC)
rjboy
igniter comes on flame comes on for about 15 seconds then igniter clicks off along with flame and then no heat rest of cycle
rjboy
#2 Posted : Tuesday, October 30, 2012 5:55:46 AM(UTC)
rjboy
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
#3 Posted : Tuesday, October 30, 2012 2:48:27 PM(UTC)
Would the igniter glow again or not?
Make sure the dryer exhaust is clean and the vent hose behind the dryer is not kinked or twisted.
Here are the breakdown diagrams and Parts for Maytag MDG4806AWW Dryer - AppliancePartsPros.com
rjboy
#4 Posted : Wednesday, October 31, 2012 4:41:48 AM(UTC)
rjboy
dryer exhaust vent is fine
diconnected hose and samething happens. igniter glow red gas turns on then flame for aboit 15 seconds than everything clicks off
#5 Posted : Wednesday, October 31, 2012 3:38:00 PM(UTC)
...Would the igniter glow again or not?...
Did I miss the answer?
rjboy
#6 Posted : Thursday, November 1, 2012 6:01:44 AM(UTC)
rjboy
Have Maytag Dryer Model #MDG4806AWW with no heat. Dryer igniter glows flame comes on for about 15 seconds and shuts off. Dryer vent is free of lint,tested everything for continuity is ok, I think its the gas valve. This model you can't just replace the coils. How do I replace the whole assembly. Thanks Rick
#7 Posted : Thursday, November 1, 2012 4:00:51 PM(UTC)
Originally Posted by: rjboy Go to Quoted Post
...This model you can't just replace the coils...
Hi Rick,
Why do you think you can't? Yes you can. Just try the coil kit Part number: 279834
Part number: 279834
rjboy
#8 Posted : Friday, November 2, 2012 1:59:08 PM(UTC)
rjboy
Replace coils and iginiter glows red,flame comes on for 15 seconds and clicks off. duct isn't clogged, tested everything else for continuity and check out ok. What else can it be? Maytag Dryer model # MDG4806AWW
#9 Posted : Friday, November 2, 2012 3:59:11 PM(UTC)
Check out the blower wheel. Make sure it's not slipping at the motor shaft.
If there is nothing wrong, replace the hi-limit thermostat (#10 at the diagram).
- The blower wheel Part number: 56000
Part number: 56000
- The hi-limit thermostat Part number: AP4052097
GE fridge water dispenser slows to trickle, speeds up when filter is twisted (Refrigerator & Freezer Repair)
by Guest 1/11/2024 5:03:35 AM(UTC)
Basic things need on Cricket (Trash Compactor Repair)
by Johnalex 7/6/2022 11:07:18 PM(UTC)
Water barely trickles from dispesmser with filter installed (Refrigerator & Freezer Repair)
by BLEBOW 6/5/2022 11:17:17 AM(UTC)
need help getting trick to open cooktop for service (Oven Repair (including Ranges and Cooktops))
by av8ndoc 9/21/2015 10:59:30 PM(UTC)
Tricky dishwasher kick plate (Dishwasher Repair)
by AppliancesRcool 1/19/2015 1:37:07 PM(UTC)
Water trickles and tiny ice cubes (Refrigerator & Freezer Repair)
by louisd 3/7/2014 6:05:33 PM(UTC)
Water trickles when off (Washer Repair)
by Porkins 3/14/2013 7:59:40 AM(UTC)
tricky (for me ) problem! (Washer Repair)
by gpl2112 12/14/2012 10:04:12 AM(UTC)
Wierd Refrigerator Trick (Refrigerator & Freezer Repair)
by ALConfederate 8/21/2012 5:24:00 PM(UTC)
Washer during spin cycle sound like brick in drum and spins slower and unevenly (Washer Repair)
by w_hurt 4/11/2012 6:26:54 AM(UTC)
rickfry1 (Washer Repair)
by rickfry1 1/28/2012 6:24:05 AM(UTC)
GE washer shock replacement any tricks? (Washer Repair)
by Jayword 12/22/2011 11:27:49 AM(UTC)
Cold water only trickles; normal setting problems (Washer Repair)
by bench 9/29/2011 4:22:11 PM(UTC)
Cold water trickling (Washer Repair)
by mommahuck 6/21/2011 5:44:20 PM(UTC)
by wamplersabin 6/3/2011 1:52:45 PM(UTC)
