soldierboy
#1 Posted : Saturday, October 27, 2012 10:53:38 AM(UTC)
soldierboy
I have a GE gas dryer. My dryer will not run I have power comming from the outlet to the wire conector insid ethe dryer. But I have no power going to the motor I have tested all sensor and the were all good. I just installed a new door switch and a timer. I get no reading at the motor power source I think it could be the safety switch even though I got good readings I bypass the start switch and still nothing.:eek:
gabe_1981
#2 Posted : Sunday, October 28, 2012 12:11:15 AM(UTC)
gabe_1981
I believe GE also has a idler pulley safty switch ... Its purpose is to not allow the dryer to run if the belt is broken or come off ... Check the belt and let me know what you find
soldierboy
#3 Posted : Sunday, October 28, 2012 8:21:14 AM(UTC)
soldierboy
The belt is good so is the switch just no power comming into the motor.
gabe_1981
#4 Posted : Sunday, October 28, 2012 8:28:05 AM(UTC)
gabe_1981
The only other thing I can think of that would do that is the thermal fuse ... It should be located in the back on the blower housing
gabe_1981
#5 Posted : Sunday, October 28, 2012 8:38:40 AM(UTC)
gabe_1981
Sorry I'm wrong ... On GE its located on the element sheild top right
Maytag Atlantis gas dryer model MDG7400AWW (Dryer Repair)
by Guest 6/13/2024 10:59:46 AM(UTC)
Speed Queen gas dryer Model SDG809WF (Dryer Repair)
by Guest 6/3/2024 11:05:10 AM(UTC)
Samsung Gas Dryer no power (Dryer Repair)
by glenn55 5/19/2024 3:33:32 PM(UTC)
MGD6000BWW Maytag gas dryer (Dryer Repair)
by Guest 5/17/2024 11:37:29 AM(UTC)
1998 Maytag Gas Dryer Drum Issue Has Me Stumped (Dryer Repair)
by semaas 4/22/2024 9:44:18 PM(UTC)
Whirlpool gas dryer model WGD8300SW2 (Dryer Repair)
by Guest 4/20/2024 7:14:50 AM(UTC)
Kenmore Gas Dryer Running Hot (Dryer Repair)
by Guest 3/30/2024 6:24:53 AM(UTC)
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
Kenmore gas dryer model 110.96742701 (Dryer Repair)
by Guest 2/8/2024 9:07:42 AM(UTC)
Maytag MDG8400AWW gas dryer not drying clothes (Dryer Repair)
by tvr4 12/31/2023 2:45:43 PM(UTC)
Samsung Gas Dryer - Model DVG50M7450* (Dishwasher Repair)
by Carl B 10/26/2023 2:05:00 PM(UTC)
Alternate T-stat for Speed Queen gas dryer (Dryer Repair)
by Guest 10/14/2023 12:59:47 PM(UTC)
Maytag gas dryer problem with model MDG5500AWW (Dryer Repair)
by Guest 4/15/2023 1:25:03 PM(UTC)
Drum repair of old Speed Queen gas dryer (Dryer Repair)
by Guest 3/13/2023 7:58:37 AM(UTC)
DLGX8001W gas dryer clicks on control board but wont start (Dryer Repair)
by Guest 3/12/2023 10:17:53 AM(UTC)
