3 Pages<123
Simon / APP Team
#21 Posted : 12 years ago
Simon / APP Team
Groups: APP Team
Hi.
Remove the vent hose from the dryer and run one load. If that doesn't make any difference - replace the hi-limit thermostat.
Simon.
Clueless2
#22 Posted : 12 years ago
Clueless2
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
Simon.
Went to test it today, and now the gas won't come on at all. Took the wires off the high limit thermostat on the burner duct and checked for continuity -- the switch is closed at room temperature. With everything hooked up, the ignitor comes on for 8 seconds, then it shuts off. What can be wrong? What else to check?
Simon / APP Team
#23 Posted : 12 years ago
Simon / APP Team
Groups: APP Team
Hi.
If the ignitor cycling on/off but there is no gas - replace the control coils Part number: 279834
Part number: 279834
There is a small chance that the gas valve is bad and cause the coils damage but consider the price try the coils first.
Simon.
New Kenmore Elite 796 Gas Dryer Won't Heat (Dryer Repair)
by Guest 2 years ago
Gas dryer won't heat (Dryer Repair)
by pino2424 10 years ago
Kenmore Gas Dryer won't Heat (Dryer Repair)
by rboysen 11 years ago
Signature Gas Dryer Won't Heat (Dryer Repair)
by jsellnow 11 years ago
LG gas dryer won't heat up (Dryer Repair)
by Farmer85 11 years ago
Whirlpool Gas Dryer Won't Heat (Dryer Repair)
by jonellem 12 years ago
Whirlpool Duet Gas Dryer Won't Heat Up (Dryer Repair)
by evanr99 12 years ago
by ejohnso6 13 years ago
by markdeveer@gmail.com 13 years ago
by sunshine2 14 years ago
GE gas dryer won't heat (Dryer Repair)
by deadmusk 14 years ago
Brand New Gas Dryer Won't Heat (Dryer Repair)
by AMLove 14 years ago
by TimMN 14 years ago
by ikohn 14 years ago
by scolmery 14 years ago
3 Pages<123
