CYCLOPS43
#1 Posted : 12 years ago
CYCLOPS43
Freezer Cooling Fine But Refridgerator Not Cooling.i Took The Panel Off Inside The Freezer An The Fan Is Working Fine But The Coil Inside Is Frozen Over Completely All The Way To The Compresser,i Mean Huge Ice Build Up I Need Help
#2 Posted : 12 years ago
I cannot find any info on the given model number ( ET18JKXRNRO).
tried AppliancePartsPros and the Whirlpool site.
Are you sure it is not a ET18JKXRWR0
CYCLOPS43
#3 Posted : 12 years ago
CYCLOPS43
The Model # Is Right The Refridge Is 26yrs. Old
#4 Posted : 12 years ago
The closest I could find to your model was an ET18JKXRWR0 so the below is for that unit.
With a little luck yours will be a close match.
Parts for Whirlpool ET18JKXRWR0 Refrigerator - AppliancePartsPros.com
Sounds like a defrost problem.
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
Manually force a defrost cycle by turning the defrost timer cam (Item 4 in Cabinet Separator section ) till the fans and compressor turn off.
There is usually a hole in the cover to let you do this without taking anything apart.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item 33 in Unit Parts section ) from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat (Item 35 in Unit Parts section ) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
Ge Profile Side By Side Refridgerator Not Cooling, Freezer Works Good (Refrigerator & Freezer Repair)
by balabask 12 years ago
Maytag French Door Refridgerator not cooling (Refrigerator & Freezer Repair)
by tnt4him 13 years ago
Whirlpool Gold Refridgerator not cooling (Refrigerator & Freezer Repair)
by mwceyler 14 years ago
refridgerator not cooling (Refrigerator & Freezer Repair)
by gary lecky 14 years ago
by flslavings 14 years ago
Whirlpool refridgerator not cooling (Refrigerator & Freezer Repair)
by gdriekho@ctcis.net 14 years ago
Refridgerator not cooling, I hear the fan but don't feel any cold (Refrigerator & Freezer Repair)
by LHadz 14 years ago
Refridgerator not cooling / freezer is good (Refrigerator & Freezer Repair)
by kwatt5 16 years ago
refridgerator not cooling but compressor runs (Refrigerator & Freezer Repair)
by bpetska 16 years ago
by tagrick 16 years ago
