kwatt5
#1 Posted : Thursday, June 18, 2009 11:30:57 AM(UTC)
kwatt5
Fridge is cooling to around 40 at the coldest setting. Freezer is is down to 20 on the 4.5 setting. Light snow in the back of the freezer.
kwatt5
#2 Posted : Thursday, June 18, 2009 11:37:24 AM(UTC)
kwatt5
Freezer is between 0 and 10 now
#3 Posted : Thursday, June 18, 2009 7:45:39 PM(UTC)
Remove the rear panel in the freezer and check the defrost heater and the defrost thermostat (#14 & #21 on the diagram) for continuity. The defrost thermostat must be cold at that time.
If there is nothing wrong then replace the adaptive defrost control (#23 on the diagram).
The diagrams I used for references are for the model similar to yours, but part numbers are different.
- The part number for the adaptive defrost control is AP3959125
- The part number for the defrost heater is AP3557499
- The part number for the defrost thermostat is AP2150145
