2 Pages12>
Donna MacDonald
#1 Posted : Sunday, October 14, 2012 10:43:53 AM(UTC)
Donna MacDonald
This is a glass top stand alone range.
After a self-cleaning cycle, the oven didn't come up to set temperature a couple of times and then seemed to self-correct.
On the next self-cleaning cycle, the same thing happened, the oven kind of works but is not working properly....it doesn't come up to full temperature. But this time the large element no longer works and the light for that element won't go off even when turned to OFF.
I've heard this is common and that these ovens are being sold with self-cleaning features that basically ruin the overn.
Is there two different problems going on now or just one? What part(s) do I need to replace here?
Donna MacDonald
#2 Posted : Sunday, October 14, 2012 3:12:12 PM(UTC)
Donna MacDonald
Whoops, I was meaning that the large element on the stovetop is no longer working, not the oven element (though the oven is not heating up)
#3 Posted : Monday, October 15, 2012 2:48:42 PM(UTC)
Hi Donna,
The model number you posted is incomplete. Verify and repost it please.
Donna MacDonald
#4 Posted : Monday, October 15, 2012 4:20:10 PM(UTC)
Donna MacDonald
KERC500HWH2 is the full model number!
#5 Posted : Monday, October 15, 2012 5:55:50 PM(UTC)
More likely the problem is a bad switch for this burner but there is a chance for the heating element to be bad as well. The best way to find out which part has to be replaced is to check them for continuity.
Here are the breakdown diagrams and Parts for Whirlpool KERC500HWH2 Range - AppliancePartsPros.com
Donna MacDonald
#6 Posted : Monday, October 15, 2012 6:39:23 PM(UTC)
Donna MacDonald
Thanks, we will check.
But what about the oven not heating to temperature? All of this happened at once after a self-clean cycle.....grrrrer
#7 Posted : Tuesday, October 16, 2012 3:34:47 PM(UTC)
Can you describe it more detailed please?
Donna MacDonald
#8 Posted : Friday, October 19, 2012 4:16:37 PM(UTC)
Donna MacDonald
Sometimes the oven heats to the right temperature and sometimes it doesn't. Sometimes it only heats to half the temperate set. But this only happened right after a self-clean cycle.
#9 Posted : Friday, October 19, 2012 5:21:08 PM(UTC)
Originally Posted by: Donna MacDonald Go to Quoted Post
...Sometimes it only heats to half the temperate set..
How did you know that? Did you measure the temperature inside the oven?
Donna MacDonald
#10 Posted : Saturday, October 20, 2012 7:37:37 AM(UTC)
Donna MacDonald
I was roasting some vegetables and they never browned or cooked properly just shrivelled up. I roast veggies frequently so I knew something was wrong. I have two oven thermometers and they were both registering 200 when the oven was set to 425. Then the next time I used the oven, it worked. Then then next two times the temperature was not coming up to what I set it to again. Like that. And this happened after a self clean cycle.
Kitchenaid KSRG25FKSS15 Refridg buzz/rattle on compressor start (Refrigerator & Freezer Repair)
by Guest 6/23/2024 8:35:15 AM(UTC)
Kitchenaid refrigerator and freezer intermittently to warm (Refrigerator & Freezer Repair)
by Guest 6/18/2024 12:12:20 PM(UTC)
Kitchenaid KDTE254ESS1 Heater Element (Dishwasher Repair)
by charlie9876 5/28/2024 8:18:41 AM(UTC)
KitchenAid KSC25INSS01 (Refrigerator & Freezer Repair)
by KKellyNC 5/23/2024 4:25:25 AM(UTC)
Kitchenaid Oven range Superba kgsc308lss0 not heating up (Oven Repair (including Ranges and Cooktops))
by rattty 5/19/2024 6:51:16 PM(UTC)
Kitchenaid KDTM604KPS0 (Dishwasher Repair)
by Guest 5/12/2024 5:24:44 AM(UTC)
KitchenAid freezer gasket needed (Refrigerator & Freezer Repair)
by Kris Ballew 4/30/2024 6:27:57 PM(UTC)
KitchenAid freezer door stuck (Refrigerator & Freezer Repair)
by willeaton 4/18/2024 7:31:34 AM(UTC)
KitchenAid KSC25INSS01 issues (Refrigerator & Freezer Repair)
by KKellyNC 4/16/2024 7:28:06 PM(UTC)
Kitchenaid KSSC48QMS02 (Refrigerator & Freezer Repair)
by VinRenzi 4/2/2024 6:26:11 AM(UTC)
Kitchenaid Refrigerator Ice chute frosting up and clogging (Refrigerator & Freezer Repair)
by Guest 3/26/2024 9:05:12 AM(UTC)
Built-In Kitchenaid Mdel KSSC42QMS00 Refrigerator (Refrigerator & Freezer Repair)
by Guest 3/25/2024 6:29:18 AM(UTC)
KitchenAid KSSP42QTS00 Ice dispenser leaking (Refrigerator & Freezer Repair)
by sternern 3/20/2024 2:21:47 PM(UTC)
Kitchenaid ktdm354dss3 doesn’t close completely at the top (Dishwasher Repair)
by Guest 2/29/2024 12:36:40 PM(UTC)
KitchenAid Gar Range - Oven Intermittent Lighting (Oven Repair (including Ranges and Cooktops))
by JDinKTX 2/25/2024 5:05:21 AM(UTC)
2 Pages12>
