monkeumanksc
#1 Posted : Wednesday, December 5, 2007 12:51:40 PM(UTC)
monkeumanksc
I have a bosch diswasher SHU9955 UC/12 (FD 8105 -)
Water is continously running into it.
Do i most likely need:
A) Water valve assembly - Made by Bosch for Bosch dishwashers. Part Number: AP3783031 made by BOSCH
OR
B) Water inlet system Part Number: AP2802392 made by BOSCH
Thanks in advance.
Kevin
Sorry about the red and blue ink, copied test from chat and I could not figure out how to change the color before my post.
#2 Posted : Wednesday, December 5, 2007 12:56:27 PM(UTC)
What happens if you unplug the dishwasher for a few minutes?
monkeumanksc
#3 Posted : Wednesday, December 5, 2007 12:59:26 PM(UTC)
monkeumanksc
Dishwasher is built in. I have not yet thrown the breaker on it. Do you think that would help? Water flows in regardless as to whether the unit is turned on or off.
#4 Posted : Wednesday, December 5, 2007 1:02:07 PM(UTC)
Normally the power cord should be plugged into an outlet under the sink.
monkeumanksc
#5 Posted : Wednesday, December 5, 2007 1:08:43 PM(UTC)
monkeumanksc
I will check that when I get home and post additional info later tonight. Thanks for your responses.
I have already ordered the:
Water valve assembly but I now think that I might need the Water inlet system instead.
#6 Posted : Wednesday, December 5, 2007 1:39:32 PM(UTC)
More possible the control board, not the water inlet system.
misterfixall
#7 Posted : Wednesday, December 5, 2007 6:33:51 PM(UTC)
misterfixall
if there is no power to dishwasher +water still comes into tub ,water valve is needed.
monkeumanksc
#8 Posted : Monday, December 10, 2007 4:42:43 AM(UTC)
monkeumanksc
Gene Thanks a lot!
It seems that you nailed it.
On Saturday, I was getting ready to replace the water valve assembly, but before I did, I flipped the breaker, and waited a few minutes. When I turned the breaker back on, and ran the dishwasher the issue had been resolved.
Thanks to all.
Monkeyman
Guest (6)
What Part Do I Need??? (Refrigerator & Freezer Repair)
by got2git1 3/6/2013 9:07:08 PM(UTC)
what part do i need???? (Washer Repair)
by nmckaskle 9/28/2012 4:17:03 PM(UTC)
duet dryer what part do I need? (Dryer Repair)
by RHonda Pitts 8/1/2012 12:50:36 PM(UTC)
what part do i need? (Dishwasher Repair)
by whitesox17 9/28/2010 3:35:20 PM(UTC)
what part do i need? Fridgidaire Gallery Dryer (Dryer Repair)
by jenna.cox 4/28/2009 6:10:24 AM(UTC)
What part do I need? (Oven Repair (including Ranges and Cooktops))
by TamSan 1/17/2009 4:43:59 PM(UTC)
what part do i need? (Washer Repair)
by agitator 7/27/2007 9:50:19 AM(UTC)
