RobertBlas
#1 Posted : Thursday, October 4, 2012 7:02:48 PM(UTC)
RobertBlas
About a month ago we noticed the items on the top shelf of the fresh food section freezing. The temperature control was set at the factory setting. I turned it down some and the fresh food thawed out. About a week later it started freezing again so again I turned it down again. Right now, it is just above 0 (zero) on the temperature control and things are starting to freeze again.
If I turn it to 0 the damper control closes, just above 0 and it opens. There is no frost or frozen anything on the back of the freezer. I hate to spend the $200+ on a new control box assembly only to find out it's something else.
Any help or thoughts? Thanks, RB
#2 Posted : Saturday, October 6, 2012 12:48:46 AM(UTC)
You might have system problems. Measure the stabilized freezer temperature and post.
RobertBlas
#3 Posted : Monday, October 8, 2012 1:18:34 PM(UTC)
RobertBlas
Sorry for the delay in response, was out of town and couldn't check it. I'll check that and post it.
RobertBlas
#4 Posted : Wednesday, October 10, 2012 11:59:47 AM(UTC)
RobertBlas
Tested freezer temp, and it is steady at 0 F, -18 C. Testing fridge side currently. Seems that the temperature on the freezer is good.
RobertBlas
#5 Posted : Wednesday, October 10, 2012 1:22:56 PM(UTC)
RobertBlas
Fridge temp is 28F, -2 C. The temp control in the fridge is at it's lowest point without turning it off completely.
#6 Posted : Thursday, October 11, 2012 12:51:32 AM(UTC)
Replace the cold control, the one that turns the compressor off. Make sure you put the new control sensing wire exactly where the old on was.
RobertBlas
#7 Posted : Friday, October 12, 2012 3:06:05 PM(UTC)
RobertBlas
I just saw this reply. Some reason I didn't get notified. Do you know what part number this would be for Model #FRS26HF6BW2. Seems there are a couple of Cold Controls. Thank you tremendously for your help!!!
#8 Posted : Saturday, October 13, 2012 12:46:51 AM(UTC)
Look at the control view on this site, either the control on the right, or left will turn off the compressor, replace that one.
RobertBlas
#9 Posted : Thursday, October 18, 2012 4:35:08 AM(UTC)
RobertBlas
Got the part, actually purchased the entire control box assembly since it was just a little more and I could sell parts I didn't need if necessary. Anyways, got it all hooked up last night and the temp in the fridge side only comes down to 52F and freezer is only 48F. Pretty sure I hooked everything up the same it was.
Any thoughts?
#10 Posted : Friday, October 19, 2012 12:48:49 AM(UTC)
Is the compressor running?
