2rpolce@charter.net
#1 Posted: : Sunday, October 7, 2012 7:24:16 AM(UTC)
2rpolce@charter.net
Timer quick working on my 20yr old Kenmore electric dryer (Model 96273800). All heat functions still work but timer doesn't. I replaced the timer with a new one from Appliance Parts Pro (Part Number 9830714 but it still doesn't work; just stays on the setting you start with. What should I try next?
#2 Posted : Friday, October 12, 2012 2:45:37 AM(UTC)
Your model number seems to be missing the first 3 digits.
Kenmore numbers are usually 3 numbers, a period and then 8 more numbers.
Does the timer not advance in both auto and timed dry modes?
The reason I ask is that on many units the timer motor gets power through different circuit paths depending on the mode.
2rpolce@charter.net
#3 Posted : Friday, October 12, 2012 8:36:03 AM(UTC)
2rpolce@charter.net
Thanks for the response. The Kenmore Model No. is 110.96273800.
The timer will advance in the "Timed Dry" mode but will not shut off.
The timer will not advance in the other three modes: "Air Dry", "Knit/Delicate", or "Normal/Perm Press" modes.
2rpolce@charter.net
#4 Posted : Friday, October 12, 2012 8:37:32 AM(UTC)
2rpolce@charter.net
. Your assistance is greatly appreciated.
#5 Posted : Friday, October 12, 2012 12:47:50 PM(UTC)
Parts for Kenmore Dryer 11096273800 - AppliancePartsPros.com
I cannot find a wiring diagram for this unit. Do you have one?
If it has one odds are it is stored in the control console.
Unplug the unit and set the unit to any non timed dry mode. Now check Timer Switch 0 (TM to OR). It should be 0 ohms.
This is the contact set that sends power to the timer motor when not in timed dry.
If OK, check the resistor. It should be around 5,000 ohms. This reduces the 240 heater voltage to 120 for the timer motor. Should be connected to OR of Timer Switch 0.
Check the heater coil should be about 8 to 12 ohms. Also check that each side is infinite ohms to the frame (ground)
I am doing a bit of guessing on the above so do not take it as gospel.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
Dryer timer replacement help (Dryer Repair)
by Guest 6/20/2024 8:14:36 AM(UTC)
Amana Electric dryer timer for model LEA50AL (Dryer Repair)
by Guest 5/20/2024 5:37:01 AM(UTC)
GE dryer timer issue (Dryer Repair)
by Guest 5/8/2024 11:47:16 AM(UTC)
GE Dryer Timer and Housing (Dryer Repair)
Belarus Guest 3/25/2024 7:47:59 AM(UTC)
Dryer Timer Humming (Dryer Repair)
by terzolino 4/6/2023 10:18:16 AM(UTC)
Kenmore Dryer Timer Power Resistor Rating (Dryer Repair)
by mhall264 3/19/2021 9:04:39 AM(UTC)
Dryer timer shorting - help me verify my rationale (Dryer Repair)
by jeromio 1/29/2020 6:51:31 PM(UTC)
Whirlpool dryer timer knob (Dryer Repair)
by robertjhebert 10/27/2019 8:50:18 AM(UTC)
Kenmore dryer timer or no timer (Dryer Repair)
by Jester1x 10/25/2019 8:47:13 PM(UTC)
Whirlpool dryer timer won't stop running. (Dryer Repair)
by ppipowerclass 4/2/2018 2:18:22 PM(UTC)
Wiring Help On GE Dryer Timer (Dryer Repair)
by Kierancypher 6/16/2017 11:00:27 AM(UTC)
Dryer Timer Compatibility (Dryer Repair)
by Paulvolter 5/28/2017 6:48:02 PM(UTC)
dryer timer release brackets (Dryer Repair)
by lcolquitt 5/24/2017 2:50:20 PM(UTC)
Kenmore Gas Dryer Timer (Dryer Repair)
by keepitfromthedump 5/24/2017 2:18:27 PM(UTC)
dryer timer will not advance (Dryer Repair)
by Jlb86 2/24/2017 4:24:03 PM(UTC)
