REPAIRTHIS
#1 Posted : Tuesday, April 26, 2011 5:49:21 PM(UTC)
REPAIRTHIS
Roper washer 4 speed combination 8 cycle won't drain, removed timer (FSP PART NO 3948852B), it doesn't appear to be burt out. Nothing is stuck in draining either.
sidfink43
#2 Posted : Wednesday, April 27, 2011 12:14:55 PM(UTC)
sidfink43
Two things to check first.
1. the lid switch
2. the pump itself to see if anything is caught in it.
kristimorris72@yahoo.com
#3 Posted : Thursday, September 27, 2012 8:08:54 AM(UTC)
how do you check the lid switch is not working
#4 Posted : Thursday, September 27, 2012 8:13:00 AM(UTC)
how do you check the lid switch to see if it not working
sidfink43
#5 Posted : Thursday, September 27, 2012 4:57:17 PM(UTC)
sidfink43
Open up the console, disconnect the switch and by pass it with a piece of wire. If the machine spins and did not before the switch is bad.
skmcorvette
#6 Posted : Monday, October 22, 2012 4:35:24 PM(UTC)
skmcorvette
Thank you,
Great call.
I have some knowledge of how things work. Just couldn't figure this one out. Timer would stop in same place everytime. Played with timer could get it to drain. So logic would say Timer. Ordered new timer still same problem. Followed your advise messed with lid switch wiring....Click started draining. Thank You!!!!!!
sidfink43
#7 Posted : Monday, October 22, 2012 4:51:57 PM(UTC)
sidfink43
Great, thanks for letting everyone know how it worked out.
Roper washer wont drain or spin (Washer Repair)
by tj1217 8/13/2014 6:33:05 AM(UTC)
Roper Washer Wont Drain or Agiate and hums from Power Knob (Washer Repair)
by Rho 8/3/2009 10:10:05 AM(UTC)
Roper washer wont drain (Washer Repair)
by Kford 11/17/2008 11:17:04 AM(UTC)
