Jean Leonard
#1 Posted : Wednesday, September 26, 2012 2:17:17 PM(UTC)
Jean Leonard
My Whirlpool refrigerator is not cooling things despite the fact I set up to the coolest position. I have already replaced the thermostat but that does not help. Any suggestions on what could be wrong which causes not to work properly?
Thanks,
#2 Posted : Thursday, September 27, 2012 1:59:14 AM(UTC)
Replacement parts for Whirlpool ED25CQXHW02 SIDE-BY-SIDE REFRIGERATOR | AppliancePartsPros.com
Need more info.
What is not cooling fresh food and/or freezer?
What is running and what is not (fans, compressor etc.)
Is the any cooling or none at all?
Is compressor cycling, off or always on?
Is the compressor on and can you feel it vibrating?
Jean Leonard
#3 Posted : Monday, October 1, 2012 7:18:49 AM(UTC)
Jean Leonard
Thanks, Denman for your reply and sorry for taking that long to reply with more info; had to deal with some other critical issues.
It is only the "fridge part" that is not cooling the juices, food, etc. The ice-maker/freezer works normally, and the compressor, fans all are okay. I checked the compressor, it is vibrating as normal. Since I replaced the old thermostat with a new one, could it be something else that causes the fridge not to work, maybe the "defrost Timer?
Thanks again,
#4 Posted : Monday, October 1, 2012 1:48:27 PM(UTC)
Are you sure you got it back together properly Check that the linkage (Items 11, 15 and 23 in Section 3) is opening the door of the diffuser (Item 24 in Section 10). This lets cold air into the fresh food side.
Also that the vent lower down on the wall between the freezer and fresh food sections is clear on both sides.
A defrost problem can show up first in the fresh food side and later in the freezer but it has been a while so I do not think it is a defrost problem.
kenmore/lg fridge not cooling (Refrigerator & Freezer Repair)
by rleescott 4/16/2024 4:52:09 AM(UTC)
LG fridge not cooling - freezer and ice maker fine - doesn’t look to be defrost related either (Refrigerator & Freezer Repair)
by Guest 7/25/2022 6:04:54 PM(UTC)
Kenmore Elite Fridge Not Cooling or Defrosting (Refrigerator & Freezer Repair)
by ktd.ajd 8/15/2020 6:47:12 PM(UTC)
fridge not cooling good (Refrigerator & Freezer Repair)
by corvairbob 7/27/2020 2:46:12 PM(UTC)
33 year old GE fridge not cooling (Refrigerator & Freezer Repair)
by stevebass 7/11/2020 4:05:50 PM(UTC)
Fridge not cooling enough, but Freezer is fine (Refrigerator & Freezer Repair)
by corriganama 8/19/2019 10:48:58 AM(UTC)
LG LMXC23467D fridge not cooling (Refrigerator & Freezer Repair)
by trkinspector 7/26/2019 6:28:02 PM(UTC)
LG fridge LFC23760ST freezer not freezing, now fridge not cooling (Refrigerator & Freezer Repair)
by blairm 1/20/2019 1:40:44 AM(UTC)
Samsung RF263 Fridge Not Cooling (Refrigerator & Freezer Repair)
by Deke1 6/15/2018 4:05:20 PM(UTC)
Maytag French door fridge not cooling down (Refrigerator & Freezer Repair)
by Sworddylan 10/8/2017 6:50:20 PM(UTC)
Fridge not cooling, freezer is cold (Refrigerator & Freezer Repair)
by ashtong63 9/28/2017 7:22:18 PM(UTC)
by richardwilliamsfaia 4/30/2017 11:14:36 AM(UTC)
Fridge not cooling. No frost on coils. (Refrigerator & Freezer Repair)
by miketh2005 2/20/2017 3:24:09 PM(UTC)
Haier fridge not cooling (Refrigerator & Freezer Repair)
by GraceC 11/1/2016 12:11:48 PM(UTC)
Bevearge Fridge not Cooling (Refrigerator & Freezer Repair)
by abenb 9/10/2016 3:37:47 PM(UTC)
