I have a Maytag Refrigerator, model MFI2569VEM1. The freezer is working just fine, but I can't get the fridge compartment to cool enough. I have it set at 34 and the coldest I can get the fridge compartment is 48 degrees F. I have already replaced the fan, thermistor, and the computer board in the back and still no improvement. I have also made sure none of the vents are blocked and removed all frost. I have suspected the damper and held it open to see if that was the issue or if it would make a difference, but that has not caused any changes either. If anyone has any ideas, I would be forever grateful; I really like this fridge and want to save it.
