veryfrustrated
#1 Posted : Tuesday, September 9, 2008 9:40:59 AM(UTC)
veryfrustrated
I recently purchased a motor - part #WH49X10035 - from appliance parts pro for my GE washer. The wiring harness is different from original on machine. I need a wiring diagram for the new motor - any help out there?
samene
#2 Posted : Monday, April 6, 2009 11:46:43 AM(UTC)
samene
I'm in the same boat. I am replacing a wh20x10009 with a WH49X10035. The female wiring harness on the old motor is a 1x9 array while the new motor is 3x3. It is my understanding that the new motor comes with a 3x3 male connector, the wires from which mostly terminate in cut and stripped wire ends.
I am assuming I need to cut off the old 1x9 male connector and crimp the old wires to those on the new connector. The wire colors don't seem to match up identically, though.
Did you ever figure out which wires to connect?
#3 Posted : Tuesday, April 7, 2009 3:05:34 PM(UTC)
The installation instructions posted here: http://forum.appliancepartspros...acing-2-speed-motor.html
Front Loader washing machine will not fill. E5E error code. (Washer Repair)
by jjuly 7/3/2024 12:25:33 PM(UTC)
GE Top Loader Washing Machine Leaking from bottom (Washer Repair)
by Guest 6/13/2024 9:46:30 AM(UTC)
whirlpool washing machine model wtw57esvw0 (Washer Repair)
by Guest 5/7/2024 7:57:17 AM(UTC)
Help! Washing machine on repeat rinse cycle (Washer Repair)
by cali.poppy 4/29/2024 9:08:28 AM(UTC)
Frigidaire Affinity Washing Machine - Leaking only sometimes (Washer Repair)
by omf_24 2/24/2024 4:45:41 PM(UTC)
Stem question about Naytag 2-belt washing machine (Washer Repair)
by Hotrodjohn71 1/2/2024 7:50:48 AM(UTC)
Maytag Oasis HE Washing Machine (Washer Repair)
by Guest 12/8/2023 12:55:45 PM(UTC)
Whirlpool Washing Machine won't start/fill (Washer Repair)
by greekguy7 12/8/2023 4:53:34 AM(UTC)
whirlpool model wtw7300dw2 washing machine (Washer Repair)
by Guest 11/8/2023 9:27:17 AM(UTC)
MVWB965HC0 Washing Machine - Need Service Manual or Video to Replace Touchpad and Control Assembl (Washer Repair)
by Guest 10/30/2023 8:11:10 PM(UTC)
Best vintage, American made washing machines (Washer Repair)
by Guest 10/30/2023 5:27:34 AM(UTC)
Washing machine not washing clothes properly (Washer Repair)
by Guest 9/20/2023 11:56:24 AM(UTC)
Washing Machine fill with water but will not spin, rinse or agitate. (Washer Repair)
by jmaiso 9/1/2023 7:04:07 AM(UTC)
Washing machine do not complete the cycle (Washer Repair)
by Guest 8/16/2023 10:02:15 AM(UTC)
Mayag washing machine - possibly locked motor? (Washer Repair)
by crp0499 5/19/2023 3:02:19 AM(UTC)
