The handle broke at the bottom connection. I have the replacement part and can remove the top screw that shows through the door. I don't know how to remove the bottom screw whose head is not visible.
Groups ready for retrieval: Registered
go to repair clinic .com there is agreat explanation. there is an inner plastic strip that can be removed to get the screw out
