sheri vliet
#1 Posted : 16 years ago
sheri vliet
The light that tells the oven temp has been getting fainter and fainter over the last few years. The range still works very well but we are almost unable to detect the temperature setting unless the house is very dark! Is this a major repair or just a matter of unscrewing the oven door and popping in a new light? (wishful thinking). i'd appreciate anyone's input. thanks.
#2 Posted : 16 years ago
If the clock display dimmed then the correction is to replace the clock.
- The part number for the clock is AP2591902
Here are the break down diagrams and Replacement parts for FRIGIDAIRE FES367CESA | AppliancePartsPros.com
sheri vliet
#3 Posted : 16 years ago
sheri vliet
i appreciate the info about replacing the clock in my oven. is this something a professional needs to do or could my (reasonably handy with tools) husband do it? again, thanks for the info.
sheri vliet
#4 Posted : 16 years ago
sheri vliet
is replacing the clock in the oven door complicated or could my (reasonably handy with tools) husband do it? what is the time involved? again, thank you for your info.
sheri vliet
#5 Posted : 16 years ago
sheri vliet
is replacing the clock in the oven door something that a (reasonably handy with tools) husband could do? what is the time involved?
#6 Posted : 16 years ago
This part is not too difficult to replace yourself. Pull the range out of the wall and remove the back control panel cover.
Range repair (Oven Repair (including Ranges and Cooktops))
by shalling 13 years ago
electric range repair (Oven Repair (including Ranges and Cooktops))
by Phillip88 14 years ago
Range Repair (Oven Repair (including Ranges and Cooktops))
by angels5491 14 years ago
Gas Range Repair Help (Oven Repair (including Ranges and Cooktops))
by l_harding 15 years ago
by wtravis 16 years ago
Hotpoint Range Repair (Oven Repair (including Ranges and Cooktops))
by jbox 16 years ago
by pcroe 16 years ago
by lamson471 18 years ago
