pcroe
#1 Posted : Friday, June 12, 2009 12:43:03 PM(UTC)
pcroe
I received your Repair Kit P/N 340032 for my Roper range, which is gas. Your shipping person tells me I received the correct part. However, the instruction sheet states that this for "Free Standing Electric Ranges." Is this the correct part for a gas range?
Also, the existing controller is a Robertshaw unit. The instructions for the replacement part give directions for rewiring the ground and for rewiring once of the leads to the three-pin connector. Do I need to make the rewiring changes for a gas range?
I look forward to your response.
Dan O.
#2 Posted : Friday, June 12, 2009 6:03:08 PM(UTC)
Dan O.
That might be the part number of one of the components in a kit but not for the kit itself. What is the part number of the whole kit (probably on its box) that you received?
The same replacement control may be used in different applications. I don't know of any specific differences needed for use between a gas or electric range model.
If your installation has those components described, my guess would be yes, they likely need to be changed on your model as well. I have no personal experience with your installation though.
JMO
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
Range repair (Oven Repair (including Ranges and Cooktops))
by shalling 6/17/2012 6:52:55 PM(UTC)
electric range repair (Oven Repair (including Ranges and Cooktops))
by Phillip88 7/21/2011 4:44:12 AM(UTC)
Range Repair (Oven Repair (including Ranges and Cooktops))
by angels5491 5/31/2011 6:08:07 AM(UTC)
Gas Range Repair Help (Oven Repair (including Ranges and Cooktops))
by l_harding 3/25/2010 9:25:41 AM(UTC)
by wtravis 7/11/2009 11:00:03 AM(UTC)
Hotpoint Range Repair (Oven Repair (including Ranges and Cooktops))
by jbox 6/30/2009 11:59:24 AM(UTC)
by sheri vliet 4/6/2009 7:22:45 AM(UTC)
by lamson471 8/2/2007 7:38:42 PM(UTC)
