hmoore@wfofr.com
#1 Posted : Sunday, April 5, 2009 5:50:28 PM(UTC)
hmoore@wfofr.com
Dryer won't start...switches do not respond. Checked the circuit breaker and it's fine.
#2 Posted : Monday, April 6, 2009 2:11:00 AM(UTC)
Replacement parts for WHIRLPOOL LET6634DQ0 | AppliancePartsPros.com
Here is the wiring diagram
https://www.servicematters.com/d...0Sheet%20-%203401728.pdf
The above is pretty blurry so he is the wiring from a different model but it looks the same as yours
https://www.servicematters.com/d...0Sheet%20-%203406688.pdf
Does your interior light work as it uses the same side of the line as the motor. Also if you just looked to see if the breaker was OK, turn it off/on a couple times slowly. Sometimes you can loose half the line without tripping the breaker. Best to check it with a meter.
High on the list is the thermal fuse in the motor's circuit. This is item 8 in Section 3 (on the blower case).
If you do not have a meter you can check it by:
Unplug the unit. THIS IS CRITICAL AS A DRYER USES 240 VOLTS WHICH IS LETHAL.
Short the two wires from the fuse together
Tape them up so they cannot short to the frame
Plug it in and give it a try.
If the fuse is blown replace it ASAP as it is a critical safety device.
Also clean and check your vent system and the blower wheel.
Often the cause of this fuse blowing.
Other likely suspects are the door switch and the push to start switch.
Hold the door switch in manually to see if it is just the actuator.
All the above can be checked with a meter with the unit unplugged which is the safest way to do it.
I would suggest you purchase a meter. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
hmoore@wfofr.com
#3 Posted : Monday, April 6, 2009 4:00:44 PM(UTC)
hmoore@wfofr.com
Originally Posted by: denman Go to Quoted Post
Denman,
Thanks for your quick, detailed answer. I replaced the thermal fuse with no change and then focused on the door switch, which is bad. How do I take the top off to get to it...all it needs is the arm.
#4 Posted : Monday, April 6, 2009 5:18:08 PM(UTC)
This should help
http://www.applianceaid.com/wpdryer_how-to.html
Start at the following line as you should not have to take the front off.
To go further in the disassembly, lift the cover from the lint filter or if yours is the one with a filter and cover together, remove the whole filter.
Whirlpool Dryer Won't Start (Dryer Repair)
by agjr200hp 2/5/2017 5:36:21 AM(UTC)
Whirlpool Dryer Won't Start- Help! (Dryer Repair)
by NikTy15 5/3/2015 6:59:24 AM(UTC)
Whirlpool dryer won't start (Dryer Repair)
by cmarley304 8/19/2014 6:07:34 PM(UTC)
by jdbell1114 3/17/2014 5:58:20 PM(UTC)
by emontoute 8/4/2013 10:01:22 AM(UTC)
by Turtleman1961 1/18/2013 5:52:20 PM(UTC)
Whirlpool Dryer won't start (Dryer Repair)
by adsch 6/26/2012 7:55:27 PM(UTC)
Whirlpool Dryer won't start - buzzing (Dryer Repair)
by David Mitchell 1/14/2012 11:52:35 AM(UTC)
by gunworks 12/14/2011 6:47:15 PM(UTC)
by patarnotte@comcast.net 12/6/2011 1:57:13 PM(UTC)
Whirlpool Dryer won't start, but hums (Dryer Repair)
by gmreeves2 12/1/2011 8:16:57 PM(UTC)
by JWCL 11/29/2011 6:43:51 AM(UTC)
by moonie777 5/13/2011 8:59:04 AM(UTC)
by zebra47cb 2/24/2011 2:53:01 PM(UTC)
Whirlpool Dryer won't start in dryer mode. (Dryer Repair)
by hol99 12/24/2010 1:06:56 PM(UTC)
