2 Pages12>
Mselfjr
#1 Posted : Thursday, August 23, 2012 5:36:50 PM(UTC)
Mselfjr
Our oven gets extremely hot then starts beeping and flashing a f10 error code. I have to flip the breaker to get it to stop. It will cook a turkey in an hour and a frozen pizza in about 5 minutes. I've read post with different answers from control panel issues to temp probe issues. They didn't say that their oven got extremely hot though. I think the run away f10 code is correct but what do I fix to keep it from getting so hot?
Mselfjr
#2 Posted : Friday, August 24, 2012 5:15:09 AM(UTC)
Mselfjr
Originally Posted by: ChadSimpson Go to Quoted Post
That sounds to me like a bad internal regulator. Those things can have their coating flake off over time from the heat. What you could do is put about half a pound of unused kitty litter in an oven safe dish and bake it for about 20 minutes. That will release some nitrates and coat that regulator back up pretty good. Be sure to use the unscented kind.
Can i just buy a new one and put it in? Do you know the part number? Thanks
Mselfjr
#3 Posted : Friday, August 24, 2012 8:05:16 AM(UTC)
Mselfjr
Thermal regulators can be hard to come by. They don't make those available for direct purchase. You'd have to harvest one from another unit, and I wouldn't suggest anyone that isn't DCA certified try to install one as they must be installed with live power in order to sync up the couplers. That's not the kind of voltage you want to be messing around with. I say try the kitty litter trick. I've been in this business for 12 years and I've found that the simplest solution is often the best way to go. Either that or bring in a professional.
10-4. I'll let you know if it works. Will attempt it this weekend.
Mselfjr
#4 Posted : Friday, September 7, 2012 5:21:03 AM(UTC)
Mselfjr
ok, the kitty litter didn't work and now it isn't even flashing the F10 code, it is just tripping the breaker.
Simon / APP Team
#5 Posted : Friday, September 7, 2012 8:55:22 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Definitely replace the control board
Part number: 316462841
Check if all heating elements including convection are good.
Here are the breakdown diagrams and Replacement parts for Frigidaire PLES389ECI ELECTRIC RANGE | AppliancePartsPros.com
Simon.
Simon.
Mselfjr
#6 Posted : Friday, September 7, 2012 10:40:29 AM(UTC)
Mselfjr
Do you think the temp probe is an issue? Thanks
Simon / APP Team
#7 Posted : Friday, September 7, 2012 12:25:50 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
When you turn the oven off at the control board and it's still heating up that means the relay in the control stock.
Check the oven sensor using the multimeter set to 10 kohm.
At room temperature the resistance should be about 1100 ohm.
The sensor Part number: 316217002
Simon.
Mselfjr
#8 Posted : Monday, September 10, 2012 5:38:48 AM(UTC)
Mselfjr
It doesn't continue to heat up when we turn it off, it just gets real hot when you have it on, no matter what temp you have it set on. Then it gets so hot it would start flashing the f10 code and beeping and now it is flipping the breaker. Do you think it would be in my best interest to get an expert out or just change the control panel? I'm definitely capable of doing it, i just don't want to spend a bunch of money replacing things if i don't need too.
Simon / APP Team
#9 Posted : Monday, September 10, 2012 9:51:14 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Check the oven sensor as I suggested first and if it's OK - replace the control board.
If you don't feel comfortable about this - call a pro.
Simon.
Mselfjr
#10 Posted : Sunday, October 7, 2012 3:41:09 PM(UTC)
Mselfjr
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
Simon.
Ok the temp sensor was fine and I replaced the control panel. The old one had a burned spot around one of the plugs on the back which was obviously the issue. I plugged in the new one and everything seemed to be fine. We tried to use it today and after about 5 minutes the breaker tripped and the oven was off. What does that sound like now? I was thinking a short somewhere.
Guest (4)
Frigidaire F10 code-runaway temperature (Oven Repair (including Ranges and Cooktops))
by wolverine1012 2/21/2013 11:22:18 AM(UTC)
2 Pages12>
