The display showes F-11 Code. I ran a diagnostic test up to C:4 Works (ie Fills ect...) At C:4 There is no motor rotations and F-4 occures. I can restart the diagnostic test and quick advance to C:6 and get the unit to drain, but F-11 will come up after 1 minute of drain. The motor ohms on winding is 6 each. The tacho generator is 118 ohms. I replaced the MCU and still get F-11. what can i do to pinpoint the problem? what about the T-generator readings, the tech sheet gives none for that part of the motor?
