Oven temperature takes off; stove shows F10 code and beeps. You can turn the oven off but when you restart it the same thing happens?
Worth repairing or time for a new one? How to troubleshoot?
Groups: APP Team
Hi. First, check using the multimeter the temperature sensor's resistance. You can do it at the control board 15 pin plug between pins 12-13. At room temperature you should read about 1100ohm. Replace if it's off Part number: 316490001
Originally Posted by: Simon / APP Team  Hi. First, check using the multimeter the temperature sensor's resistance. You can do it at the control board 15 pin plug between pins 12-13. At room temperature you should read about 1100ohm. Replace if it's off Part number: 316490001
If the sensor is good - replace the control board Part number: 316557205
Simon- The molex plug has no wires in positions 12, 14, or 15, unless I'm counting from the wrong end.
Groups: APP Team
Hi.
You are looking at the wrong end. Look careful at the end of the plug, they should be marked.
Simon.
