wolverine1012
#1 Posted: : Thursday, February 21, 2013 11:22:18 AM(UTC)
wolverine1012
Oven temperature takes off; stove shows F10 code and beeps. You can turn the oven off but when you restart it the same thing happens?
Worth repairing or time for a new one? How to troubleshoot?
Simon / APP Team
#2 Posted : Thursday, February 21, 2013 1:48:35 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
First, check using the multimeter the temperature sensor's resistance. You can do it at the control board 15 pin plug between pins 12-13.
At room temperature you should read about 1100ohm.
Replace if it's off
Part number: 316490001
If the sensor is good - replace the control board
Part number: 316557205
You may need an overlay too
Part number: 316419305
Here are the breakdown diagrams and Backguard parts for Frigidaire GLEF379DQG - AppliancePartsPros.com
Post the results.
Simon.
wolverine1012
#3 Posted : Friday, February 22, 2013 8:37:35 AM(UTC)
wolverine1012
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
Replace if it's off
Post the results.
Simon.
Simon-
The molex plug has no wires in positions 12, 14, or 15, unless I'm counting from the wrong end.
Simon / APP Team
#4 Posted : Friday, February 22, 2013 10:46:09 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
You are looking at the wrong end. Look careful at the end of the plug, they should be marked.
Simon.
