swiss54
#1 Posted : Friday, August 17, 2012 5:19:43 PM(UTC)
swiss54
The ice maker is leaking water down the back of frige on the inside. Do you think there my be a leak in the insert tube or maybe the water tube?
Or maybe the clamp is broke! I haven't started to fix until I hear from someone there.
Thanks,
swiss54
MayTech
#2 Posted : Friday, August 17, 2012 10:41:59 PM(UTC)
MayTech
Check to see if the fill cup on the back of the ice maker is frozen up with ice. If it is then you may have a bad/leaky water valve. If not, check the mold on your ice maker for flaking/peeling coating, if peeling it may need a new ice maker.
Also are you sure it's coming from the ice maker? If it's water leaking from the freezer into the fresh food section it may be a clogged or frozen drain tube, you'll have to remove the lower and rear panel in the freezer to access it.. If the drain line is frozen over you'll have to clear out the ice and install a heat probe kit. (#AP3119957)
hope this helps.
GE refrigerator leaking water from bottom (Refrigerator & Freezer Repair)
by Raidem8 5/19/2015 10:50:03 AM(UTC)
Whirlpool refrigerator leaking water (Refrigerator & Freezer Repair)
by goosemasterkl 1/1/2014 8:14:42 AM(UTC)
Samsung refrigerator leaking water (Refrigerator & Freezer Repair)
by wendyjoe 5/27/2013 8:57:36 AM(UTC)
Samsung refrigerator leaking water on fresh food side (Refrigerator & Freezer Repair)
Belarus TWAppliance 2/10/2013 11:16:13 AM(UTC)
Frigidaire Refrigerator leaking water (Refrigerator & Freezer Repair)
by GLORY S 5/16/2012 7:48:26 PM(UTC)
E-Wave Refrigerator leaking water (Refrigerator & Freezer Repair)
by Mmcr179 12/10/2011 6:02:29 AM(UTC)
Refrigerator leaking water on the inside. (Refrigerator & Freezer Repair)
by rlarsen 7/8/2011 10:06:33 AM(UTC)
Refrigerator Leaking Water Inside (Refrigerator & Freezer Repair)
by PTB197 1/24/2011 5:47:10 PM(UTC)
freezer part of refrigerator leaking water (Refrigerator & Freezer Repair)
by timchi29 6/23/2009 3:25:32 PM(UTC)
