hfox1
#1 Posted : Wednesday, August 15, 2012 9:08:52 AM(UTC)
hfox1
what part is bad causing the regfigetator part to be too warm
Simon / APP Team
#2 Posted : Wednesday, August 15, 2012 10:34:31 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Locate in the fresh food top left rear the vent and check if there any cold air coming out of it.
If not - open the freezer door and check again.
If the air is coming through with the freezer door open , then most likely it' the defrost system problem.
If not - the air damper control.
Here are the breakdown diagrams and Replacement parts for Frigidaire FRS26R4AB6 Frigidaire/refrigerator | AppliancePartsPros.com
Post the results.
Simon.
sherif59
#3 Posted : Wednesday, August 15, 2012 12:23:59 PM(UTC)
sherif59
GE ref and freezer side by side model #GSS255SGMD frig was not cooling properly I noticed that the coil in back freezer was cover with ice so I replaced the defroster heater and defroster control but i still have same problem so i replaced the control panel but i still same problem coil still cover with ice but if i melt the ice frig and freezer work great only for a few days and it seem defroster heater not working and it is new
can u give me an advice or help thanks
Simon / APP Team
#4 Posted : Thursday, August 16, 2012 9:12:04 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
What do you mean "control panel"? Is it the mother board at the back? What is the part number?
Simon.
