bmassey26
#1 Posted : Tuesday, December 7, 2010 9:08:02 AM(UTC)
bmassey26
Installation instructions for the replacing the heating element.
Joe / APP Team
#2 Posted : Tuesday, December 7, 2010 11:04:27 AM(UTC)
Joe / APP Team
B,
Here is a basic heater removal, installation , instructions as you requested.
Good Luck,
1. Unplug dryer or disconnect power.
2. Remove the rear panel.
3. To remove the thermal cutoff (TCO)
a) Remove the two wires from the TCO
terminals.
b) Remove the hex-head screw, unhook
the end of the bracket, and remove
the TCO.
4. To remove the heater and inlet thermistor/
high-limit thermostat
a) Lift the locking tab and remove the
2-wire connector from the inlet thermistor.
b) Remove the wire connector from the
high-limit thermostat terminal.
c) Remove the two wire connectors from
the heater terminal block
d) Remove the two hex-head screws from
the heater assembly and remove the
assembly
e) Using a flat-blade screwdriver, pry the
inlet thermistor terminal off the heater
terminal, and remove the thermistor from
the assembly.
Reverse procedure and test unit for operation.
vanj333
#3 Posted : Friday, August 10, 2012 11:19:04 AM(UTC)
vanj333
thank you for the instruction B.
Joe / APP Team
#4 Posted : Friday, August 10, 2012 11:41:27 AM(UTC)
Joe / APP Team
Van,
You're quite welcome. We hope all went OK, and you're dryer is up and running.
Drop us a line anytime you need assistance on your aplliances, we're here to help.
Thanks Again,
vanj333
#5 Posted : Friday, August 10, 2012 1:06:24 PM(UTC)
vanj333
Originally Posted by: Joe / APP Team Go to Quoted Post
Van,
Thanks Again,
thank you again and I wll do so part should be here tomorrow.So it will be up and running about this time. You guys save me and alot of other people alot of pain and suffering.
Joe / APP Team
#6 Posted : Friday, August 10, 2012 1:11:51 PM(UTC)
Joe / APP Team
Van,
Thanks Again.
Once you're done with the repair, post a report of how things went, any quick tips you may have , etc. that will help other Forum viewers in the future. We'd appreciate it.
Thanks,
vanj333
#7 Posted : Sunday, August 12, 2012 4:31:44 PM(UTC)
vanj333
Dang it I have replaced thermal fuse nothing. I have replaced the heating element nothing still no heat. im at a loss guys but that not hard for me i dont work on dryer very often. so tell me guys what should I do next??:confused:
vanj333
#8 Posted : Monday, August 13, 2012 12:47:52 PM(UTC)
vanj333
I need some help on what I will do next im thinking of getting the thermal shut off kit. But waiting on your responses.
Joe / APP Team
#9 Posted : Tuesday, August 14, 2012 6:49:02 AM(UTC)
Joe / APP Team
Van,
The thermal fuse kit, could be the issue. If replacing it, doesn't solve the issue, you'll need to get access to a multi meter,
Part number: AP5641753
so we can test circuits and voltages, and get your dryer up and running.
Thanks,
Kenmore 100 dryer Heating Element (Dryer Repair)
by postalservice21 3/27/2024 6:43:17 AM(UTC)
Oven Heating Element Wire Repair (Oven Repair (including Ranges and Cooktops))
by JT5 11/22/2023 5:20:00 AM(UTC)
Left side heating elements (Oven Repair (including Ranges and Cooktops))
by Guest 11/19/2023 10:24:48 AM(UTC)
Whirlpool oven - only one heating element? (Oven Repair (including Ranges and Cooktops))
by smithhead 11/3/2023 2:42:01 PM(UTC)
Heating element won't turn off on Maytag dishwasher (Dishwasher Repair)
by Guest 8/2/2023 6:10:10 AM(UTC)
new heating element, but still not heating (Dishwasher Repair)
by ScotofBV 7/13/2023 5:47:30 PM(UTC)
A blue wire going to heating element in freezer is blown (Refrigerator & Freezer Repair)
by Guest 6/5/2023 1:14:06 PM(UTC)
Frigidaire Dishwasher Heating Element warped? (Dishwasher Repair)
by Guest 4/8/2023 10:48:21 AM(UTC)
Miele (4882) Lower Heating Element (Oven Repair (including Ranges and Cooktops))
by drmoose00 3/22/2023 7:09:47 PM(UTC)
Electrolux range (2008) -heating element won't turn off (Oven Repair (including Ranges and Cooktops))
by xain1z2z 3/19/2023 1:21:18 PM(UTC)
Whirlpool Stove working but both heating elements are not (Oven Repair (including Ranges and Cooktops))
by Guest 2/20/2023 1:06:16 PM(UTC)
Oven wall heating Element broke while cooking (Oven Repair (including Ranges and Cooktops))
by Guest 9/12/2022 1:21:34 PM(UTC)
Dishwasher heating element wont shut off (Dishwasher Repair)
by dperna 2/23/2022 12:20:33 PM(UTC)
LG WM3050C thermistor/heating element help (Washer Repair)
by Guest 10/2/2021 5:29:07 AM(UTC)
Heating element will not shut off (Oven Repair (including Ranges and Cooktops))
by Guest 8/13/2021 8:50:42 AM(UTC)
