troy5262
#1 Posted : 13 years ago
troy5262
I have a Frigidaire LTF7000ESO in the spin cycle will not work. All other wash modes work normally, except at the end "spin mode", it will not spin. The drain works fine. In looking through some of the forums, I discovered a suggested diagnostic test. I ran the test and I am getting error code: 59
Could you please tell me what this code means and what part I would need to fix it. Thank you in advance for your help.
#2 Posted : 13 years ago
Perform the test 10 as instructed in the Tech sheet (page 3) and post the results.
Here are the breakdown diagrams and Replacement parts for Frigidaire LTF7000ES0 Frigidaire/washer | AppliancePartsPros.com
troy5262
#3 Posted : 13 years ago
troy5262
Thank you for taking the time to reply. I performed test 10 and turned out I needed to replace the speed control board. Ordered the part and it was here in a day. Problem solved!!!!
#4 Posted : 13 years ago
You are welcome. We're glad you were able to fix it.
Thank you for the feedback.
troy5262
#5 Posted : 13 years ago
troy5262
So, I guess I jumped the gun a little. After replacing the part the washer worked perfect for about 10 loads. Now, its back to the same problem of it not completing the fast spin. Any further suggestions?
#6 Posted : 13 years ago
Sorry about it. Try to perform the same test and post the results.
troy5262
#7 Posted : 13 years ago
troy5262
Getting code: E47
#8 Posted : 13 years ago
This error code leads to one of the most common problem with such washers: a bad door lock.
You can find more information in one of our previous threads: http://forum.appliancepartspros...asher-wont-spin-out.html
- The door lock assembly Part number: 131763202
Please help!!!! Gas oven temp issue (Oven Repair (including Ranges and Cooktops))
by volfan54 10 years ago
Please Help!!!!!! (Microwave Repair)
by TheFreedMind 11 years ago
No heat - PLEASE help!!!! (Dryer Repair)
by Tippy73 12 years ago
Please Help!!!!!!!! (Refrigerator & Freezer Repair)
by Mr.sockerskillz 13 years ago
my freezer works fine refrigerater doesnt please help!!!!! (Refrigerator & Freezer Repair)
by ralphcarter 15 years ago
Dryer stopped running....Please HELP!!!!! (Dryer Repair)
by JerryB. 16 years ago
