troy5262
#1 Posted : Tuesday, July 31, 2012 4:26:58 PM(UTC)
troy5262
I have a Frigidaire LTF7000ESO in the spin cycle will not work. All other wash modes work normally, except at the end "spin mode", it will not spin. The drain works fine. In looking through some of the forums, I discovered a suggested diagnostic test. I ran the test and I am getting error code: 59
Could you please tell me what this code means and what part I would need to fix it. Thank you in advance for your help.
#2 Posted : Wednesday, August 1, 2012 4:51:56 PM(UTC)
Perform the test 10 as instructed in the Tech sheet (page 3) and post the results.
Here are the breakdown diagrams and Replacement parts for Frigidaire LTF7000ES0 Frigidaire/washer | AppliancePartsPros.com
troy5262
#3 Posted : Sunday, August 5, 2012 3:19:06 AM(UTC)
troy5262
Thank you for taking the time to reply. I performed test 10 and turned out I needed to replace the speed control board. Ordered the part and it was here in a day. Problem solved!!!!
#4 Posted : Tuesday, August 7, 2012 12:01:05 PM(UTC)
You are welcome. We're glad you were able to fix it.
Thank you for the feedback.
troy5262
#5 Posted : Thursday, August 9, 2012 6:10:54 PM(UTC)
troy5262
So, I guess I jumped the gun a little. After replacing the part the washer worked perfect for about 10 loads. Now, its back to the same problem of it not completing the fast spin. Any further suggestions?
#6 Posted : Thursday, August 9, 2012 6:20:14 PM(UTC)
Sorry about it. Try to perform the same test and post the results.
troy5262
#7 Posted : Tuesday, August 14, 2012 5:00:49 PM(UTC)
troy5262
Getting code: E47
#8 Posted : Wednesday, August 15, 2012 2:41:56 PM(UTC)
This error code leads to one of the most common problem with such washers: a bad door lock.
You can find more information in one of our previous threads: http://forum.appliancepartspros...asher-wont-spin-out.html
- The door lock assembly Part number: 131763202
Guest (7)
Please help!!!! Gas oven temp issue (Oven Repair (including Ranges and Cooktops))
by volfan54 7/22/2015 5:19:00 PM(UTC)
Please Help!!!!!! (Microwave Repair)
by TheFreedMind 3/16/2014 11:21:27 PM(UTC)
No heat - PLEASE help!!!! (Dryer Repair)
by Tippy73 12/14/2012 3:07:36 PM(UTC)
Please Help!!!!!!!! (Refrigerator & Freezer Repair)
by Mr.sockerskillz 2/20/2012 7:44:07 AM(UTC)
my freezer works fine refrigerater doesnt please help!!!!! (Refrigerator & Freezer Repair)
by ralphcarter 10/17/2009 10:51:04 AM(UTC)
Dryer stopped running....Please HELP!!!!! (Dryer Repair)
by JerryB. 8/17/2009 9:27:28 AM(UTC)
