I have a 15+ year old GE Monogram 42" side by side built in refrigerator model #ZISW42EMB that over the last few weeks is showing Error FF on the freezer door information panel. Usually it goes away in several hours or if I power off/on the refrigerator. I vacuumed the dust from the condenser and surrounding parts. The freezer is still cold enough. Also, the Warm Temperature light comes on for a bit but not as long as Error FF.
It appears the condenser fan runs more often than in the past.
Any suggestions would be great.
thanks
[FONT="Verdana","sans-serif"][/FONT]
Groups: APP Team
Hi.
Check the temperature in both : freezer and fresh food. Check the air flow at the damper control.See if it's open enough.
Thank you.
Simon.
Now I'm getting a CC error in additional to the FF error. The refrigerator is cold but the freezer is warmer. I have the temperature dial in the freezer set to 9. If I unplug the power for a few minutes the error messages go away for a while but return shortly.
thanks
Groups: APP Team
Hi.
If both evaporator and condenser motors are running and the condenser is clean I recommend you to call the service co. It may be a sealed system problem.
Thank you.
Simon.
Groups: APP Team
Hi.
The damper control is #216 on the diag.#5.
The sealed unit breakdown is in diag.#5.
Simon.
I have the exact problem stated by the other person. What was his solution?
