jaffman
#1 Posted : Wednesday, July 25, 2012 10:31:22 AM(UTC)
jaffman
I have a 15+ year old GE Monogram 42" side by side built in refrigerator model #ZISW42EMB that over the last few weeks is showing Error FF on the freezer door information panel. Usually it goes away in several hours or if I power off/on the refrigerator. I vacuumed the dust from the condenser and surrounding parts. The freezer is still cold enough. Also, the Warm Temperature light comes on for a bit but not as long as Error FF.
It appears the condenser fan runs more often than in the past.
Any suggestions would be great.
thanks
[FONT="Verdana","sans-serif"][/FONT]
Simon / APP Team
#2 Posted : Wednesday, July 25, 2012 2:52:44 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Check the temperature in both : freezer and fresh food.
Check the air flow at the damper control.See if it's open enough.
Thank you.
Simon.
jaffman
#3 Posted : Tuesday, August 7, 2012 7:17:10 AM(UTC)
jaffman
Now I'm getting a CC error in additional to the FF error. The refrigerator is cold but the freezer is warmer. I have the temperature dial in the freezer set to 9. If I unplug the power for a few minutes the error messages go away for a while but return shortly.
thanks
Simon / APP Team
#4 Posted : Tuesday, August 7, 2012 12:03:08 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
If both evaporator and condenser motors are running and the condenser is clean I recommend you to call the service co. It may be a sealed system problem.
Thank you.
Simon.
jaffman
#5 Posted : Wednesday, August 8, 2012 8:54:10 AM(UTC)
jaffman
I've contacted a technical from GE to come and take a look.
I cannot find the Damper control to check airflow. Can you tell me where to look on parts diagram, Replacement parts for General Electric ZISW42EMB Refrigerator | AppliancePartsPros.com?
Also, i want to take the panel off in the freezer to check the coils for frost. Is their a service manual to help me understand the best way to do this?
thanks
dave
Simon / APP Team
#6 Posted : Wednesday, August 8, 2012 9:39:07 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
The damper control is #216 on the diag.#5.
The sealed unit breakdown is in diag.#5.
Simon.
bobrien6
#7 Posted : Friday, June 27, 2014 7:51:49 AM(UTC)
bobrien6
I have the exact problem stated by the other person. What was his solution?
