gwilson321@hotmail.com
#1 Posted : Sunday, July 29, 2012 3:20:46 PM(UTC)
My washer will only fill with water, it will not wash, rinse, spin or drain.
ApplianceJunk
#2 Posted : Sunday, July 29, 2012 3:26:07 PM(UTC)
ApplianceJunk
If the motor does not sound like it's running check the lid switch.
If the motor is running check the motor coupler.
#3 Posted : Sunday, July 29, 2012 4:55:37 PM(UTC)
the motor is not running,,,,already did the lid check.
ApplianceJunk
#4 Posted : Sunday, July 29, 2012 4:59:08 PM(UTC)
ApplianceJunk
Then check for a bad connections on the wire harness were it plugs into the motor.
If the connections look ok then I would have to start troubleshooting with a multimeter and the tech sheet as it could be a bad timer or motor.
#5 Posted : Sunday, July 29, 2012 5:08:36 PM(UTC)
already changed the timer switch.
ApplianceJunk
#6 Posted : Sunday, July 29, 2012 5:18:32 PM(UTC)
ApplianceJunk
Then check for a bad connection on the wire harness were it plugs into the motor.
Guest (4)
Older Msytag top load washer main belt tension on model LA612 (Washer Repair)
by Guest 6/29/2024 10:22:44 AM(UTC)
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
GE Top load washer not draining (Washer Repair)
by Guest 6/25/2024 4:59:12 PM(UTC)
Washer won’t spin with load (Washer Repair)
by Guest 6/25/2024 5:32:07 AM(UTC)
Samsung Top Load Washer (Washer Repair)
by welchjames65@hotmail.com 6/21/2024 3:08:07 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 6/13/2024 10:48:53 AM(UTC)
GE Profile Washer not draining and water not hot (Dishwasher Repair)
by Guest 6/8/2024 9:00:21 AM(UTC)
Kenmore washer 110.81821110 (Washer Repair)
by Hitzemup 6/5/2024 3:57:12 PM(UTC)
LG Washer 0E (OE) Error After Pump Motor Replaced (Solved) (Washer Repair)
by kilimar 6/3/2024 2:34:22 PM(UTC)
Whirlpool duet washer front load (Washer Repair)
by Guest 6/3/2024 9:57:09 AM(UTC)
Kenmore 70 series washer grinding (Washer Repair)
by Higginsdog 5/28/2024 4:17:38 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
Kenmore 90 Series top-loader washer won't agitate/drain/spin (fixed?) and makes metallic noise (Washer Repair)
by deepdiver359 5/21/2024 8:09:21 PM(UTC)
GE washer grinding noise (Washer Repair)
by gefixin 5/20/2024 2:01:39 PM(UTC)
