bizzybeez
#1 Posted : Monday, July 23, 2012 4:24:28 AM(UTC)
bizzybeez
I recently replace the eoc on my fridgedaire range/oven then afer a few times of use the f10 error code tripped again any suggestion or what the next step would be
Simon / APP Team
#2 Posted : Monday, July 23, 2012 1:39:36 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Please provide the model number of the unit.
Simon.
bizzybeez
#3 Posted : Tuesday, July 24, 2012 10:02:13 AM(UTC)
bizzybeez
Simon, here is the model #plefm399dca
Sincerely, Jeff
Simon / APP Team
#4 Posted : Tuesday, July 24, 2012 11:11:45 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
The F10 code means the over temperature conditions. most likely the temperature probe is bad.
To test it you need a multimeter set to 10000 ohm.
Normal resistance is approx. 1100 ohm at room temp.
The sensor Part number: 316490001
Here are the breakdown diagrams and Replacement parts for Frigidaire PLEFM399DCA Frigidaire/electric Range | AppliancePartsPros.com
Thank you. Post the results.
Simon.
bizzybeez
#5 Posted : Monday, August 6, 2012 3:39:26 AM(UTC)
bizzybeez
Simon I ordered and replace the temp probe and used the oven 3-4 times with no error codes. Thanks for all of your help
Sincerely, Jeff
Simon / APP Team
#6 Posted : Monday, August 6, 2012 8:14:15 AM(UTC)
Simon / APP Team
Groups: APP Team
You are very welcome.
Simon.
Frigidaire Stove F10 Error (Oven Repair (including Ranges and Cooktops))
by ronusmc 1/4/2014 8:08:21 AM(UTC)
F10 error (Oven Repair (including Ranges and Cooktops))
by ciglady 9/9/2013 1:20:16 PM(UTC)
Frigidaire Range F10 Error (Oven Repair (including Ranges and Cooktops))
by Cephus 8/9/2012 1:37:10 PM(UTC)
F10 error message random beeping (Oven Repair (including Ranges and Cooktops))
by favored 3/16/2012 9:27:24 AM(UTC)
Kenmore Electric Range - F10 Error (Oven Repair (including Ranges and Cooktops))
by blackwidow71 6/19/2011 3:02:24 PM(UTC)
Kenmore Range F10 error (Oven Repair (including Ranges and Cooktops))
by kaf27033 3/7/2011 12:17:32 PM(UTC)
F10 Error Code; Runaway Temperature (Oven Repair (including Ranges and Cooktops))
by Keith Hocky 10/18/2010 4:11:10 PM(UTC)
f10 error (Oven Repair (including Ranges and Cooktops))
by ohiosparky 10/13/2010 1:41:28 PM(UTC)
What does an F10 Error Code Mean? (Oven Repair (including Ranges and Cooktops))
by gwest2010 1/19/2010 6:38:10 AM(UTC)
f10 error code (Oven Repair (including Ranges and Cooktops))
by lindi 1/15/2008 9:54:51 AM(UTC)
