clwcomp
#1 Posted : Tuesday, July 17, 2012 9:06:35 AM(UTC)
clwcomp
Top oven bake element not working. Have replaced element. Have continuity on current element. Have replaced sensor. Have replaced relay board (top). Have continuity from red element wire to the following on relay board: E-2N, E-4N,OVLT, Broil, CVBAK, CVRST, COOL, and L-1. Have continuity from the element white wire to L-2 on the relay board. Where do I check next? Missus is getting so hot I probably don'tneed the oven. Any assistance appreciated.
Simon / APP Team
#2 Posted : Tuesday, July 17, 2012 2:29:18 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Does the element gets 240VAC?
Does the broil works?
f it doesn't - check the hi-limit thermostat in L1(blk) to OR common for bake and broil.
Thank you.Post the results.
Simon.
clwcomp
#3 Posted : Tuesday, July 17, 2012 5:41:56 PM(UTC)
clwcomp
measuring across the 2 bake element wires there is no voltage. Both wires have continuity to the relay board. New relay board from APP. Have 240V coming off of L1/L2. Also have 240V on both sides of thermostat. The broiler does work. Convection fan works. Heat sensor appears good, approx. 1100 ohms. Bake element approx. 15 ohms. Broiler element will heat oven eventually. Will bring it to temp and hold it. Bottom oven bake and broil work fine. Thanks
Simon / APP Team
#4 Posted : Wednesday, July 18, 2012 10:27:04 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Turn the power off, take one wire off the bake element and with power on check witch leg has no 120VAC (one test lid to the ground). Trace that wire to source of 120VAC.
Post the results.
Simon.
clwcomp
#5 Posted : Wednesday, July 18, 2012 3:31:07 PM(UTC)
clwcomp
No power from L2 (e11) on the new board from APP. Yippee! Now what! Will y'all cross ship a new board?
Simon / APP Team
#6 Posted : Wednesday, July 18, 2012 4:05:53 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
When you turn the oven clock to bake do you hear the relay clicking? The same with the broil?
If don't hear the bake relay engaging then most likely it's the clock control board Part number: 71001872
If both relays clicks - try another PCB Part number: 74006612
Make sure there is 240VAC to the PCB.
Simon.
Guest (5)
GE Hotpoint Stove Bake Element not working (Oven Repair (including Ranges and Cooktops))
by Guest 3/21/2023 10:17:36 AM(UTC)
Bake Element not working everything else fine (Oven Repair (including Ranges and Cooktops))
by DBLTRAUMA 12/31/2016 5:24:27 AM(UTC)
Bake element not working in double oven (Oven Repair (including Ranges and Cooktops))
by luck11 1/11/2015 7:45:26 AM(UTC)
Bake element not working (Oven Repair (including Ranges and Cooktops))
by mcclelland 1/10/2015 12:20:06 PM(UTC)
by rrg1965 3/3/2014 9:37:12 AM(UTC)
Frigidaire wall oven, bake element not working (Oven Repair (including Ranges and Cooktops))
by Fred V 10/30/2013 5:59:41 PM(UTC)
Bake element not working. Thermostat or Controller board? (Oven Repair (including Ranges and Cooktops))
by leorosi 5/12/2013 4:40:07 PM(UTC)
Bottom bake element not working (Oven Repair (including Ranges and Cooktops))
by oldmill 6/2/2012 7:56:34 AM(UTC)
GE oven bake element not working, broil works. (Oven Repair (including Ranges and Cooktops))
by HelpMeAnyone 12/25/2011 3:39:09 PM(UTC)
Oven Bake element not working (Oven Repair (including Ranges and Cooktops))
by NickJade 11/14/2011 8:17:42 AM(UTC)
by apps2777 5/26/2011 8:56:52 AM(UTC)
by rfridley1 2/22/2011 6:45:27 AM(UTC)
Replacement bake element not working (Oven Repair (including Ranges and Cooktops))
by Bex291 1/12/2011 5:53:48 PM(UTC)
Bake element not working - Broil is fine. (Oven Repair (including Ranges and Cooktops))
by dank_01 3/10/2010 8:21:05 PM(UTC)
Wall oven bake element not working! Broil works, clock works. (Oven Repair (including Ranges and Cooktops))
by ajachyra 12/1/2009 1:37:54 PM(UTC)
