HASSELMAN
#1 Posted : Monday, December 3, 2007 8:15:33 AM(UTC)
HASSELMAN
I set temp to 400 and oven preheats in less than a minute - after 20mins oven temp only 200 deg - is this a control panel problem?
vornato
#2 Posted : Monday, December 3, 2007 8:48:57 AM(UTC)
vornato
You could check the thermostat sensor in the oven itself. It sends a message to the controls. I am not up on how to test this. But if you look for some info on posts someone may know. I believe it is either good or bad, meaning if you check it with an ohmeter, it either reads 0 or infinite or a low scale reading. Again I am not sure on the exact procedure. But it should be checked.
vornato
#3 Posted : Monday, December 3, 2007 8:58:16 AM(UTC)
vornato
Also check that your thermostat is correct. On a digital display it will be there somewhere, using the control pads you can set the thermostat. Read your owners manual. The thermostat may not be set correctly.
Lower GE wall oven won't heat up (Oven Repair (including Ranges and Cooktops))
by scalpeldoc 2/6/2019 11:56:18 AM(UTC)
Samsung Range and Oven Won't Heat Up (Oven Repair (including Ranges and Cooktops))
by neweyess 8/19/2013 5:13:28 AM(UTC)
Kenmore gas oven won't heat up properly (Oven Repair (including Ranges and Cooktops))
by Black Cherry 3/27/2013 11:12:55 AM(UTC)
The oven won't heat up. The pilot is lit and not heating oven (Oven Repair (including Ranges and Cooktops))
by Hazelave.corp 11/21/2012 3:55:15 PM(UTC)
whirlpool oven won't heat up (Oven Repair (including Ranges and Cooktops))
by smeighan 11/19/2012 4:38:18 PM(UTC)
Oven won't heat up but broiler works fine (Oven Repair (including Ranges and Cooktops))
by NJ Mom of 3 11/11/2012 4:42:15 PM(UTC)
Oven won't heat up? element and/or sensor problem?? (Oven Repair (including Ranges and Cooktops))
by renzandjo 7/18/2012 9:26:23 AM(UTC)
kitchenaid oven won't heat up (Oven Repair (including Ranges and Cooktops))
by susanm 6/5/2012 6:29:46 AM(UTC)
Oven won't heat up after self cleaning cycle (Oven Repair (including Ranges and Cooktops))
by ToughTags 2/28/2012 3:15:55 PM(UTC)
Maytag Oven Won't heat up (Oven Repair (including Ranges and Cooktops))
by Petezr 1/25/2012 6:27:38 PM(UTC)
GE Wall Oven Won't heat up (Oven Repair (including Ranges and Cooktops))
by tejyam@hotmail.com 1/17/2012 1:29:54 PM(UTC)
Oven won't heat up, need help! (Oven Repair (including Ranges and Cooktops))
by dogrobber13 8/16/2011 8:09:08 AM(UTC)
by macnchez 7/5/2011 3:19:55 PM(UTC)
Oven won't heat up (Oven Repair (including Ranges and Cooktops))
by Haf 6/12/2011 3:27:40 PM(UTC)
Maytag Gas Oven Won't heat Up (Oven Repair (including Ranges and Cooktops))
by cjklein1 4/22/2011 10:01:07 AM(UTC)
