NJ Mom of 3
#1 Posted : Sunday, November 11, 2012 4:42:15 PM(UTC)
NJ Mom of 3
The upper oven on my double wall oven has not heated properly since we lost power during Hurricane Sandy. The oven was on when the power blew out. The upper oven has a digital control panel. The broiler works fine, but when I set the oven to heat up on bake, it takes forever, and won't get above 250 degrees. The lower oven is fine. It has a dial control.
We think it is the bake element that needs to be replaced. Is that the likely cause? Or is there something else that might have happened?
Thanks.
#2 Posted : Monday, November 12, 2012 2:42:20 PM(UTC)
Hello,
You will need a simple multimeter to check the Bake heating element for continuity. Replace it if there is no continuity.
If the heating element is fine, replace the oven control board.
- The Bake heating element Part number: Y04000066
- The control board Part number: 7601M286-60
