The water dispenser is broken. The lever was working if I pushed it even farther than previous. Now it does not dispense water at all. The ice dispenser is also problematic. Can I simply purchase the whole assembly and just replace everything? This unit is old so I do not mind replacing the entire assembly.
Groups: APP Team
Hi. Open the dispenser and check the pins holding the micro switches on the bracket. Most likely they are broken. The bracket Part number: 2180226
Thanks. I ordered the part and will reply again and let you know after the install.
Groups: APP Team
Praise the Lord! The part worked! Thanks for the diagnosis and the solution!
Groups: APP Team
