mkrevo
#1 Posted : Wednesday, July 11, 2012 10:25:21 AM(UTC)
mkrevo
The water dispenser is broken. The lever was working if I pushed it even farther than previous. Now it does not dispense water at all. The ice dispenser is also problematic. Can I simply purchase the whole assembly and just replace everything? This unit is old so I do not mind replacing the entire assembly.
Simon / APP Team
#2 Posted : Wednesday, July 11, 2012 11:57:19 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Open the dispenser and check the pins holding the micro switches on the bracket. Most likely they are broken.
The bracket Part number: 2180226
mkrevo
#3 Posted : Wednesday, July 11, 2012 4:45:37 PM(UTC)
mkrevo
Thanks. I ordered the part and will reply again and let you know after the install.
Simon / APP Team
#4 Posted : Thursday, July 12, 2012 10:29:49 AM(UTC)
Simon / APP Team
Groups: APP Team
Thank you.
Simon.
mkrevo
#5 Posted : Friday, July 13, 2012 10:49:46 AM(UTC)
mkrevo
Praise the Lord! The part worked! Thanks for the diagnosis and the solution!
Simon / APP Team
#6 Posted : Friday, July 13, 2012 12:10:45 PM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome.
Simon.
Water Dispenser Broken (Refrigerator & Freezer Repair)
by CSharp 11/20/2008 6:30:48 PM(UTC)
