MWeeks
#1 Posted : Thursday, July 12, 2012 5:45:42 PM(UTC)
MWeeks
I have a Hotpoint side by side and the coils keep freezing up. Initally freezer was fine but refrigerator was too warm. Called a repairman out and he replaced the sensor in the bottom of the freezer stating if that didn't work it would be the mother board. It didn't work so I replaced the mother board, coils still froze up so I replaced the defrost themostat at that point almost 2 weeks ago. Took panel off today to check and coils are freezing up again. Removed the thermostat to check it and the digital meter I had seemed to jump around on numbers occassionally stopping around 21.9 or so, also noticed a small amount of black powder substance coming out of the thermostat when I removed it. Should I replace the thermostat? Is there any other things I should check or it could be? Thanks
#2 Posted : Friday, July 13, 2012 2:42:27 AM(UTC)
I would check the defrost heater, if black inside with a clear gap, it's blown, just order a new one on this site.
Side by side coils freezing up (Refrigerator & Freezer Repair)
by delifolk1964 6/30/2016 10:07:19 AM(UTC)
Coils freezing up on upper portion of LG refrigerator (Refrigerator & Freezer Repair)
by fll_LG 1/10/2016 1:46:38 PM(UTC)
GE gsh22kgpa fridge, coils freezing up (Refrigerator & Freezer Repair)
by crcorc 9/25/2015 7:07:16 AM(UTC)
GE dual evap Profile PS model, coils freezing over (Refrigerator & Freezer Repair)
by half-past 8/4/2015 6:35:49 PM(UTC)
freezer coils freezing up (Refrigerator & Freezer Repair)
by jpnemco 5/6/2014 7:25:45 AM(UTC)
Coils freezing over popping GFI couple times a night (Refrigerator & Freezer Repair)
by dawgface21 10/12/2013 4:51:01 AM(UTC)
HELP!!! GE Side by side coils freezing up (Refrigerator & Freezer Repair)
by billda 5/14/2013 4:42:45 AM(UTC)
coils freezing (Refrigerator & Freezer Repair)
by daniel gangloff 9/24/2012 8:37:20 AM(UTC)
by frank616 6/14/2012 1:22:16 PM(UTC)
GE side-by-side evap. coils freezing, fridge freezing at bottom and not cold at top (Refrigerator & Freezer Repair)
by jttaylor 1/23/2012 11:24:01 AM(UTC)
by gatlin95 5/12/2011 3:47:51 PM(UTC)
Frigidaire Side by Side Coils Freezing Over (Refrigerator & Freezer Repair)
by jeanie_mcc@yahoo.com 9/30/2009 10:08:13 AM(UTC)
AC coils freezing up (Heating, Ventilation, and Air Conditioning (HVAC))
by somethinggrl 6/28/2009 8:50:24 AM(UTC)
coils freezing up in freezer and frig temps warm (Refrigerator & Freezer Repair)
by dhofer 6/2/2009 6:08:17 AM(UTC)
Evaporator coils freezing over,replaced defrost timer (Refrigerator & Freezer Repair)
by crnmd 5/8/2009 2:46:05 PM(UTC)
