Washer fills but wont shut off on any setting of water level switch. I have replaced water level switch and have the same results.
Help !!!
Groups: APP Team
Hi.
When you unplug the washer does the water stops? If not - replace the water inlet valve. If it stops - check the air pressure hose and air dome for cracks, holes or obstructions.Check if it's still connected at the bottom and top.
Post the results.
Simon.
Thanks! I'll check those and see what i can find out...
Thanks Simon. Checked the water fill hose and sure enough it had worn at the plastic clamp on the side of the tub until it produced a whole. Went to Lowes and bought new hose with the same ID, installed and was back in business. Thanks Again....
Groups: APP Team
