pete1949
#1 Posted : Friday, June 29, 2012 11:57:43 AM(UTC)
pete1949
Washer fills but wont shut off on any setting of water level switch. I have replaced water level switch and have the same results.
Help !!!
Simon / APP Team
#2 Posted : Friday, June 29, 2012 5:44:23 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
When you unplug the washer does the water stops?
If not - replace the water inlet valve.
If it stops - check the air pressure hose and air dome for cracks, holes or obstructions.Check if it's still connected at the bottom and top.
Post the results.
Simon.
pete1949
#3 Posted : Saturday, June 30, 2012 4:47:35 AM(UTC)
pete1949
Thanks! I'll check those and see what i can find out...
pete1949
#4 Posted : Monday, July 2, 2012 10:59:47 AM(UTC)
pete1949
Thanks Simon. Checked the water fill hose and sure enough it had worn at the plastic clamp on the side of the tub until it produced a whole. Went to Lowes and bought new hose with the same ID, installed and was back in business. Thanks Again....
Simon / APP Team
#5 Posted : Monday, July 2, 2012 11:08:13 AM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome.
Simon.
