2 Pages12>
jdoginbako
#1 Posted : Tuesday, June 26, 2012 5:47:35 PM(UTC)
jdoginbako
My Whirlpool dryer started acting up a few weeks aga. It will not run on the timed drying setting nor will it run on the very dry/ towels setting. This means that after starting the dryer I must come bak and re start it at least once or twice to dry a load.:mad: :confused:
#2 Posted : Wednesday, June 27, 2012 5:16:05 PM(UTC)
Did you mean it takes longer time to dry a load or it stops before the cycle is done?
hankincm
#3 Posted : Wednesday, September 5, 2012 6:14:27 PM(UTC)
hankincm
Gene - Mine too stops before the cycle is done, and only runs when the timer is set to the energy preferred position
#4 Posted : Thursday, September 6, 2012 2:33:34 PM(UTC)
What is the complete model number of the dryer?
hankincm
#5 Posted : Thursday, September 6, 2012 5:59:19 PM(UTC)
hankincm
LGR8648PW0
About a year ago I replaced both the timer and solenoid coils. Last week I replaced both the Dyer Driver motor and blower wheel, because I thought that was the problem.
Thanks again
#6 Posted : Friday, September 7, 2012 5:21:11 PM(UTC)
Sounds like the problem is a bad cycling thermostat which is located on the blower housing.
- The cycling thermostat Part number: 3387134
hankincm
#7 Posted : Friday, September 21, 2012 1:16:56 PM(UTC)
hankincm
Gene - I got back from vacation, ordered the part and just installed it. However, the machine will still only start in the energy preferred position. Any other suggestions? Thanks.
#8 Posted : Saturday, September 22, 2012 11:03:02 AM(UTC)
It would not start or it would not heat in other positions?
hankincm
#9 Posted : Saturday, September 22, 2012 11:08:21 AM(UTC)
hankincm
It will not start. Thanks Gene for all your help thus far.
#10 Posted : Saturday, September 22, 2012 11:32:00 AM(UTC)
Unplug the dryer. Open the control panel. Remove the wires from the "BU" & "BK" terminals at the timer. Check for continuity across these terminals with different timer settings. Post the results,
Guest (8)
2 Pages12>
