2 Pages12>
john23
#1 Posted : Monday, March 30, 2009 9:20:23 AM(UTC)
john23
My ice machine will make noice when i push the dispense button but it does not make any ice to dispense?
#2 Posted : Monday, March 30, 2009 4:07:18 PM(UTC)
Remove the ice bin. Tape the light switch in closed position. Push the ice release lever on the dispenser and see if the auger motor (#369 on the diagram) will work. Check if the ice door in the dispenser opens. Post the results.
john23
#3 Posted : Tuesday, March 31, 2009 3:22:22 AM(UTC)
john23
Gene,
yes the ice dispenser door opens and the motor runs while doing this.
#4 Posted : Tuesday, March 31, 2009 11:02:23 AM(UTC)
John,
I'm afraid I did not get clear what exactly is wrong - the ice maker does not make ice or the dispenser does not dispense it?
john23
#5 Posted : Tuesday, March 31, 2009 11:08:07 AM(UTC)
john23
the ice maker does not make ice.
#6 Posted : Tuesday, March 31, 2009 11:33:47 AM(UTC)
If the ice maker in your refrigerator has a green LED status light then make sure the "on-off" switch on the ice maker is "on".
If the green LED status light is blinking then the ice maker is bad and has to be replaced.
If the green LED is "on" then check the water feeding tube into the ice maker for frost or ice inside. Post the results.
john23
#7 Posted : Tuesday, March 31, 2009 4:37:38 PM(UTC)
john23
it has a green LED light however then the switch is on but the light is not lit up?
#8 Posted : Wednesday, April 1, 2009 9:13:26 AM(UTC)
Looks like the ice maker has gone bad. There was a lot of problems with these electronic ice makers and GE recently introduced a newly designed electromechanical ice maker.
- The part number for the ice maker is AP4345120
john23
#9 Posted : Wednesday, April 1, 2009 9:17:39 AM(UTC)
john23
thanks for all the help. I was hoping it was something simple but apparently not. Is it possibe its a selonid or something? We had a power surge and it damage my microwave, furnace etc.
#10 Posted : Wednesday, April 1, 2009 9:26:09 AM(UTC)
If the LED is "off" with the power switch "on" then the ice maker has to be replaced. This ice maker has an electronic control board inside, which probably got damaged due to a power surge. Other parts, like the water valve, are not that sensitive and hopefully are not damaged.
Guest (4)
LG LDC24370ST Ice Maker Issues (Refrigerator & Freezer Repair)
by Guest 6/29/2024 8:55:44 AM(UTC)
Mysterious leak -Top Freezer w/Ice maker (Refrigerator & Freezer Repair)
by St.B 6/18/2024 8:40:52 AM(UTC)
Water Runs Too Long - Ice maker (Refrigerator & Freezer Repair)
by shfdyoung 6/11/2024 3:01:06 PM(UTC)
Bosch Ice Maker Dropping Ice Once Week (Refrigerator & Freezer Repair)
by Guest 5/31/2024 1:40:51 PM(UTC)
Lg ice maker leaking (Refrigerator & Freezer Repair)
by Guest 4/10/2024 2:58:55 PM(UTC)
KITCHEN AID UNDERCOUNTER ICE MAKER KUIC18NNZS0 (Refrigerator & Freezer Repair)
by kwhowell6539 3/25/2024 1:49:40 PM(UTC)
Ice maker slabbing (Refrigerator & Freezer Repair)
by Guest 3/11/2024 8:34:02 PM(UTC)
Frigidaire Freezer FPFU19F8WF4 - ice maker problem (Refrigerator & Freezer Repair)
by Eric8888 3/5/2024 11:02:19 AM(UTC)
Installing ice maker, looking for holes (Refrigerator & Freezer Repair)
by Grendel25 2/16/2024 10:02:12 AM(UTC)
ice maker in LG fridge model #LFX31925st/08 (Dishwasher Repair)
by diohabla 2/16/2024 8:36:50 AM(UTC)
Freezer holding at 22 degrees and ice maker (located in refrigerator cabin) isn't working (Refrigerator & Freezer Repair)
by eric5605 2/13/2024 4:35:48 AM(UTC)
Ice maker fiil/dump (Refrigerator & Freezer Repair)
by Guest 2/12/2024 5:46:50 AM(UTC)
GE Fridge GFE28GMKJES Ice Maker Not Working (Refrigerator & Freezer Repair)
by aopenshaw 2/9/2024 8:35:22 AM(UTC)
Ice maker issues and more? LG LFX25971 (Refrigerator & Freezer Repair)
by turtlejay 2/1/2024 5:07:00 PM(UTC)
LG French Door can the lower craft ice maker be swapped to cubed? (Refrigerator & Freezer Repair)
by Bstewart63 1/3/2024 11:45:50 AM(UTC)
2 Pages12>
