25 Pages«<1112131415>»
#121 Posted : Wednesday, May 30, 2012 12:03:54 PM(UTC)
Pull the refrigerator out of the wall. Remove the cover and make sure the compressor is running. You have to feel some vibration on a touch. Also check it's temperature. Post the results.
It's also a good time to clean the condenser.
Here are the breakdown diagrams and Replacement parts for Whirlpool GC3SHEXNS00 REFRIGERATOR | AppliancePartsPros.com
jhn0002
#122 Posted : Thursday, May 31, 2012 6:16:35 AM(UTC)
jhn0002
It seems to be the inverter that is shot. I'm going to install a new one and see if that will stand the compressor.
sdginz
#123 Posted : Thursday, June 21, 2012 6:50:49 AM(UTC)
sdginz
I have the aboove model kitchen aid side by side that recently quit making ice.
I have checked the optics by simulating a closed door and that appears to be working correctly from what I have read in the previous posts.
It does dispense water thru the door and ice if filled manually. I have also checked for blockage in the filling tube and found none. The ice maker never calls for water.
I have rotated the fingers of the ice maker manually and can hear it click but it never turns on its own.
Any ideas?
#124 Posted : Thursday, June 21, 2012 12:02:31 PM(UTC)
Swap the wires between the water valve solenoids. Push the water dispenser lever for a few seconds and check for water inside the ice maker.
If there is some water, replace the ice maker.
If there is no water, replace the water inlet valve.
- The ice maker Part number: 2198597
jhn0002
#125 Posted : Thursday, June 21, 2012 12:38:18 PM(UTC)
jhn0002
Originally Posted by: jhn0002 Go to Quoted Post
It seems to be the inverter that is shot. I'm going to install a new one and see if that will start the compressor.
I installed the new inverter and the compressor started right up. 24 hrs later, my fridge was cold and ice was in the ice maker. Has been working great ever sense.
Thanks for your help!:)
sdginz
#126 Posted : Thursday, June 21, 2012 12:39:30 PM(UTC)
sdginz
Gene thanks for your quick reply.
Can you describe for me how to swap the wires between the water valve solenoids?
Where are they located? So what your saying is that when swapped the water dispenser will trigger water flow into the ice maker. Correct?
sdginz
#127 Posted : Thursday, June 21, 2012 12:57:23 PM(UTC)
sdginz
Gene one additional question.
If I do need to replace the icemaker what is the difference between the part here on appliance pro's website versus one sold on Filter Fast for substantially less money.
Thanks.
#128 Posted : Thursday, June 21, 2012 2:09:29 PM(UTC)
You are welcome. I'm glad it's up and running.
#129 Posted : Thursday, June 21, 2012 2:27:58 PM(UTC)
The water valve is located on the back of the refrigerator. It has two solenoids: one for the ice maker and the other one for the water dispenser. Each of them has 2 wires connected to. By swapping the wires, the power from the water dispenser lever will come and energize the ice maker solenoid. If this solenoid is good and there is nothing with the water line to the ice maker, water should come into the ice maker.
About any other web site who may sell the same parts - did you check their return policy? 15% restocking fee and only 30 days for only unused parts? What are you going to do if your diagnosis was wrong and you would like to return the ice maker which you already installed?
Their price looks so suspicious, I would not surprise if they sell refurbished parts as new.
martin58boobhat
#130 Posted : Friday, July 27, 2012 9:04:54 PM(UTC)
martin58boobhat
is ther any way of checking the p.c. receiver board with a volt meter or other tool
Guest (10)
