207 Pages«<160161162163164>»
rosezhang2000
#1611 Posted : Monday, June 18, 2012 4:21:02 PM(UTC)
rosezhang2000
Ok, got it! Will try next time the frost is built up.
BTW, is there a smarter way to defrost manually than what I did, turning off the fridge and opening the door?
Thanks!
Rose
#1612 Posted : Monday, June 18, 2012 4:34:05 PM(UTC)
You can use a hair dryer.
on_mitch
#1613 Posted : Monday, June 18, 2012 5:04:57 PM(UTC)
on_mitch
Hello Gene
Not sure if my last reply went through, so here it is again.
Model FRT18S6ABL
Condenser fan runs quite, with good air flow, no strange noises,
Freezer temp is steady 10 deg F
Manually defrosted it yesterday morning, but it is already icing up at the rear panel louvers.
Any thoughts?
#1614 Posted : Monday, June 18, 2012 9:22:19 PM(UTC)
Originally Posted by: on_mitch Go to Quoted Post
Hello Gene
Model FRT18S6ABL
Any thoughts?
I would like to confirm that we are talking about the same fan. Condenser fan is on the back of the refrigerator, next to the compressor (#60 at the diagram). The evaporator fan is inside the freezer (#13 at the diagram). My question was about the evaporator fan.
How did you set the temperature controls in the fresh food compartment and in the freezer?
on_mitch
#1615 Posted : Tuesday, June 19, 2012 9:29:57 AM(UTC)
on_mitch
Hi Gene
I was referring to the fan, number 13, inside the freezer.
Please note that both fans are working when the unit is running.
As far as temperature I set dial in the fridge to the recommenced setting and the damper in freezer to the cold setting ,CCW left.
#1616 Posted : Tuesday, June 19, 2012 11:22:47 AM(UTC)
Turn the damper control in the freezer all the way toward "colder" position. Wait about 24 hours and check the temperature.
on_mitch
#1617 Posted : Tuesday, June 19, 2012 4:14:57 PM(UTC)
on_mitch
Hello Gene
Today's temp was well over 90 deg F.
I did as us asked and the freezer got down to -6 deg F, but the fridge went up to 51 deg F.
In an attempt to cool off the fridge section I turn it back to cold instead of colder, as this opens the damper, and puts more cold air into the fridge.
Rear vents in the freezer are iced up completely, so I will need to defrost the freezer tomorrow.
Mitch
#1618 Posted : Tuesday, June 19, 2012 4:25:16 PM(UTC)
Hello Gene
Mitch
Mitch,
You have to find out right position for both control knobs.
Quote:
...Rear vents in the freezer are iced up completely...
Before you will do anything, remove the rear cover in the freezer and inspect the evaporator coils.
on_mitch
#1619 Posted : Tuesday, June 19, 2012 4:38:27 PM(UTC)
on_mitch
Hello
With the freezer knob set to cold, not colder, the fridge temp is around 38 deg. F, and the freezer is at 10 deg. F. My problem is that while this works fine the evaporator coil continues to freeze up, requiring the I manually defrost the unit.
Do you think defrost heater is malfunctioning and causing this, or could it be something else?
Mitch
#1620 Posted : Tuesday, June 19, 2012 4:59:03 PM(UTC)
...the evaporator coil continues to freeze up...
Mitch,
Did you remove the evaporator cover and saw it or you think so just because you can see it through the vents?
The normal temperature in the freezer is about 0°F while the normal temperature in the refrigerator is between 36°F to 40°F on different levels. You can do it only by playing with both control knobs.
Guest (46)
Freezer is fine, refrigerator is too warm. (Refrigerator & Freezer Repair)
by mrhoagie 11/3/2012 1:46:58 PM(UTC)
Another Freezer is fine, refrigerator is too warm. (Refrigerator & Freezer Repair)
by rzeune 10/7/2010 9:19:39 AM(UTC)
by allemich 4/19/2009 8:02:07 PM(UTC)
