mchack2
#1 Posted : Sunday, June 10, 2012 2:33:07 PM(UTC)
mchack2
Whirlpool microwave door. mh1150xmb1
the plastic frame below the handle and the handle cracked and pieces broke off. I have a new door from you. I removed the outer plastic frame on the old door by removing 3 screws on the inside edge of the door. the inner door is still attached to the microwave. The new door does not want to seperate easily and i do not want to break it. can i replace the whole door or what is best and easiest. i would have thought instructions would have come with it when you spend $240 on a door.
thanks
Craig
#2 Posted : Monday, June 11, 2012 2:34:28 PM(UTC)
Hi Craig,
You don't have to take the old or new doors apart. Remove the top grille and the screw secured the top hinge.
Kitchenaid (Whirlpool) Microwave door switches (Microwave Repair)
by ForumUser1 1/11/2024 1:11:07 PM(UTC)
Kitchen Aid Combo Microwave Door Flops Open Even After Springs (Oven Repair (including Ranges and Cooktops))
by chrison600 11/19/2022 11:33:49 AM(UTC)
Microwave door issue (Microwave Repair)
by mdezrin 3/5/2022 7:50:10 AM(UTC)
DE94-02053C Microwave Door Assembly (Microwave Repair)
by caleb3po 8/7/2019 10:13:27 AM(UTC)
Whirlpool Microwave Door Sensor Part & Diagram? Need help (Microwave Repair)
by ellie0704 4/8/2019 8:26:28 AM(UTC)
microwave door replacement (Microwave Repair)
by purcel34 3/3/2019 8:59:04 AM(UTC)
Whirlpool Microwave Door Error and flipped breaker when plugged in (Microwave Repair)
by ellie0704 2/9/2019 9:12:28 AM(UTC)
ge microwave door (Microwave Repair)
by david habenicht 10/29/2018 11:26:32 PM(UTC)
Remove LG microwave door (Microwave Repair)
by papajoe 10/19/2017 1:06:47 PM(UTC)
I have to push up on microwave door to make it operate. (Microwave Repair)
by RGH0625 1/10/2017 1:17:12 AM(UTC)
Whirlpool microwave door handle broke (Microwave Repair)
by troyw66 11/9/2016 6:32:52 AM(UTC)
Microwave Door Handle (Microwave Repair)
by Dante77 7/7/2015 3:28:27 PM(UTC)
Microwave door latch (Microwave Repair)
by why? 4/28/2015 2:05:31 PM(UTC)
Maytag Microwave Door (Microwave Repair)
by Thia 9/10/2014 6:58:08 AM(UTC)
How to replace microwave door (Microwave Repair)
by crissywp 1/26/2014 5:49:32 PM(UTC)
