tallica2002
#1 Posted : Thursday, May 31, 2012 6:41:33 PM(UTC)
tallica2002
When I plug the freezer in it runs for a brief moment and then shuts off. Where should I start? any help is greatly appreciated. Thank you.
#2 Posted : Friday, June 1, 2012 12:45:51 AM(UTC)
Is anything running at that time?
tallica2002
#3 Posted : Friday, June 1, 2012 11:40:53 PM(UTC)
tallica2002
I can't say I fully understand your question but what is happening is when you plug the freezer in the light comes on the fan and compressor start for a brief moment and stop. If its been a while since you plugged it in it will run about 2 seconds if you unplug it right away and plug it back in it will run about a split second its almost like it runs just long enough until it runs into a problem.
tallica2002
#4 Posted : Saturday, June 2, 2012 8:16:22 PM(UTC)
tallica2002
I ohmed out the compressor and it tested fine.
#5 Posted : Sunday, June 3, 2012 1:56:01 AM(UTC)
Compressor ohm readings will show" normal" resistance with a low voltage ohmeter. Only 115 volts will test for burnt windings.
Something is interupting voltage to the compressor and condensing fan motor. Most probable problem is the control (Part number: AP4433141
) located behind the door panel. I fixed one of these before and found a intermittent pin on the plug, Just unplug it and plug it in, might fix it.
tallica2002
#6 Posted : Thursday, June 7, 2012 5:09:04 PM(UTC)
tallica2002
Ok I have a update on the freezer now it will run fine for about 4 hours and then all of a sudden quit we can unplug it about 10 seconds and it will go another round.
#7 Posted : Friday, June 8, 2012 12:33:27 AM(UTC)
If I remember right, you pry off the readout bezel on the freezer door to get to the control module.
tallica2002
#8 Posted : Friday, June 8, 2012 10:31:27 AM(UTC)
tallica2002
So you still think its for sure the control module?
#9 Posted : Saturday, June 9, 2012 1:20:23 AM(UTC)
That is the most probable problem.
tallica2002
#10 Posted : Saturday, June 9, 2012 10:36:18 AM(UTC)
tallica2002
Thanks for all your help I will let u know how it goes
