When I plug the freezer in it runs for a brief moment and then shuts off. Where should I start? any help is greatly appreciated. Thank you.
Is anything running at that time?
I can't say I fully understand your question but what is happening is when you plug the freezer in the light comes on the fan and compressor start for a brief moment and stop. If its been a while since you plugged it in it will run about 2 seconds if you unplug it right away and plug it back in it will run about a split second its almost like it runs just long enough until it runs into a problem.
I ohmed out the compressor and it tested fine.
Compressor ohm readings will show" normal" resistance with a low voltage ohmeter. Only 115 volts will test for burnt windings. Something is interupting voltage to the compressor and condensing fan motor. Most probable problem is the control ( Part number: AP4433141
) located behind the door panel. I fixed one of these before and found a intermittent pin on the plug, Just unplug it and plug it in, might fix it.
Ok I have a update on the freezer now it will run fine for about 4 hours and then all of a sudden quit we can unplug it about 10 seconds and it will go another round.
If I remember right, you pry off the readout bezel on the freezer door to get to the control module.
So you still think its for sure the control module?
That is the most probable problem.
Thanks for all your help I will let u know how it goes
