neeley3737
#1 Posted : Saturday, March 28, 2009 6:57:36 AM(UTC)
neeley3737
My dishwasher is 2 1/2 years old and it quit pumping water into the dishwasher. You can hear the dishwasher pump, but there is no water coming in the basin.
#2 Posted : Saturday, March 28, 2009 7:35:54 AM(UTC)
A Model Number might help others help you.
The unit does not pump water in. It simply opens a valve.
Remove the kick plate.
Valve is usually on the left hand side.
Remove the wires from the valve and measure it for continuity use a 2 Kohm scale.
If it is an open (infinite ohms) then it is shot.
If OK.
Check the over fill switch, also on the left hand side.
Float may be stuck in the up position.
The switch should be closed (0 ohms).
If OK
Reconnect the float switch
Place the timer at the start of a cycle (fill)
Measure for volts across the valves wires, should get 120 volts with door closed
If no voltage then the timer may be shot.
If OK
Either the valve is shot or the filter screen on it's input side is clogged with gunk.
Shut the water supply off.
Remove the valve and check/clean the screen.
Do not remove the screen. It is there to keep crud out of the valve which might hold the valve open and cause a flood.
If screen is clean probably the valve is shot
GE Profile Dishwasher Hums when Off (Dishwasher Repair)
by Thom64 2/7/2022 7:19:40 PM(UTC)
GE profile dishwasher PDW9980N00SS starts then stops (Dishwasher Repair)
by cfcstl 12/15/2020 8:18:18 AM(UTC)
GE Profile Dishwasher QP 47 Can't move between different Wash programs (Dishwasher Repair)
by MTHall720 3/26/2020 11:32:29 AM(UTC)
GE Profile Dishwasher Control Module (Dishwasher Repair)
by merb 11/17/2018 4:33:33 PM(UTC)
GE profile dishwasher (Dishwasher Repair)
by barnee72 1/14/2016 5:47:55 PM(UTC)
GE Profile Dishwasher lights up, but will not start (Dishwasher Repair)
Belarus cjsrinivas 12/21/2015 8:06:27 PM(UTC)
ge profile dishwasher - nut water inlet - repair or replace? (Dishwasher Repair)
by dsynadinos 3/1/2014 5:22:20 AM(UTC)
GE profile dishwasher won't drain completely (Dishwasher Repair)
by nazia 2/25/2014 5:52:10 AM(UTC)
GE Profile dishwasher GHDA696Pss doesnt drain completely (Dishwasher Repair)
by jdn9580 1/11/2014 10:15:13 AM(UTC)
ge profile dishwasher (Dishwasher Repair)
by rickcallaway 11/4/2013 8:17:53 AM(UTC)
GE Profile dishwasher motor fan (Dishwasher Repair)
by saegsblair 9/19/2013 5:45:58 AM(UTC)
GE Profile Dishwasher won't drain (Dishwasher Repair)
by tms101 9/14/2013 9:47:52 PM(UTC)
GE Profile dishwasher not cleaning well (Dishwasher Repair)
by edjr 3/30/2013 4:25:14 AM(UTC)
GE Profile Dishwasher - Constant Buzzing (Dishwasher Repair)
by diydaddy 1/25/2013 9:49:05 AM(UTC)
GE Profile Dishwasher will not fully drain (Dishwasher Repair)
by springerider 1/6/2013 6:30:22 PM(UTC)
