groucho
#1 Posted : 13 years ago
groucho
When preheating oven it makes puffing sounds and takes a long time to preheat. Almost an hour to reach temp and signal that it is preheated
Simon / APP Team
#2 Posted : 13 years ago
Simon / APP Team
Groups: APP Team
Hi.
Next time when you will use the oven open the bottom drawer and watch it's performance. How it's igniting the burner: how long it takes to light the gas, is the burner lights up completely?
Post the results.
Simon.
groucho
#3 Posted : 13 years ago
groucho
Simon,
I turned oven on ,igniter lights, two minutes later oven lights with a very short flame around bar. not even a quarter of an inch in length. after a minute fame goes out then bursts of gas is despensed causing the puffing sound and dancing flames. Flame does not stay on constant. Is there a regulater that tells amount of gas to be released?
Simon / APP Team
#4 Posted : 13 years ago
Simon / APP Team
Groups: APP Team
Hi.
Did you try the broil? If the broil works fine then check the amperage draw at the bake ignitor. If it's less than 3.2 Amp - replace the ignitor.
In case if you don't have the amp meter switch the broil ignitor with bake and then try it.
If it'll work - replace the ignitor.
The ignitor Part number: WB13K21
Thank you. Post the results.
Simon.
groucho
#5 Posted : 13 years ago
groucho
Simon I tried to switch the broil igniter, but it had a plug vs oven which had wire nuts. watching the broil one work then the oven igniter I do think it is the igniter. I just ordered the igniter through your company. Should have it in a couple days, and I will let you know how I make out.
Ron
groucho
#6 Posted : 13 years ago
groucho
Simon,
Thank you for your help. With your help, and buying the part from appliance Pro I saved close to fifty dollars.
Ron
Simon / APP Team
#7 Posted : 13 years ago
Simon / APP Team
Groups: APP Team
You are very welcome.
Simon.
