207 Pages«<3233343536>»
#331 Posted : 16 years ago
Marty,
Make sure the condenser coil (#730 on the diagram) is clean.
Here are the break down diagrams and Replacement parts for GE TBX22QABRRWW | AppliancePartsPros.com
vga75
#332 Posted : 16 years ago
vga75
Hello Gene, i juts bougth a side by side Maytag Fridge model MD5955Y and it only been working 4 days, and i feel that on the fridge side the food is just fresh and have it to the max temperature so i believe it should be fresher than that compared to another fridges that i have own in the past, what could it be? what could be wrong?
#333 Posted : 16 years ago
Measure the temperature in both compartments. Normally it suppose to be about 0°F in the freezer and 36°F to 39°F in the refrigerator. If the temperature is higher and you could not adjust it - call Maytag warranty service.
tjl
#334 Posted : 16 years ago
tjl
Gene,
My GE side by side GSL22JFPH has exactly the same problem you described in the first post. I couldn't find the defrost timer in the break down diagrams. Does my fridge have this part any way?
Thanks!
woodchuckie
#335 Posted : 16 years ago
woodchuckie
Originally Posted by: tjl Go to Quoted Post
Gene,
Thanks!
You don't have a timer. Your defrost is controlled by the motherboard. Part 801 on the diagram of your sealed system & motherboard.
Have your checked your defrost heater and defrost thermostat.
tjl
#336 Posted : 16 years ago
tjl
Not yet. I am looking for some instructions. Seems this is a right place for me. :)
#337 Posted : 16 years ago
...I am looking for some instructions...
You can find them on page 3 of this thread.
Toymit
#338 Posted : 16 years ago
Toymit
This is pretty much the same problem Ive been experiencing for the past few months. I have a Bosch KUS40 refrigerator (with freezer on top).It works fine for a few weeks then it will start to leak at the bottom of fridge,after a week or so the refrigerator part wont cool anymore but freezer part will still work fine.Then a few days later my ice cream almost turns to solid rock,so I'll switch the refrigerator off for a few days then back on and all will work fine again only for the above senario to repeat itself. Now,I cant find my model on this site probably because its only found where Im from (New Zealand) or Australia,so its kinda hard for me to find the thermostat/defrost heater and timer.I have a fair idea what they look like,its just identifying the parts properly. Any help much appreciated, (TIA).
#339 Posted : 16 years ago
The best solution I believe is to call a local Bosch representative.
tjl
#340 Posted : 16 years ago
tjl
Thanks! I have done manual defrost twice and am convinced that the problem is with the defrost control. I have been wondering how to remove the back panel of the freezer? Does the ice maker part need to be removed? Is there any step by step instructions with photos? I really don't want to mess up. Forgive me about this very newbie-ish question.
Freezer is fine, refrigerator is too warm. (Refrigerator & Freezer Repair)
by mrhoagie 12 years ago
Another Freezer is fine, refrigerator is too warm. (Refrigerator & Freezer Repair)
by rzeune 15 years ago
by allemich 16 years ago
