ajb1010
#1 Posted : Monday, May 21, 2012 2:36:03 PM(UTC)
ajb1010
Dryer wont heat.. otherwise functions properly. I have replaced the heating element and thermal fuse.. the dryer worked for a day but now does not heat again.
all circuits on new parts check out okay.
Any thoughts?
Simon / APP Team
#2 Posted : Monday, May 21, 2012 3:34:30 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
What's the complete model number of the dryer?
Simon.
ajb1010
#3 Posted : Monday, May 21, 2012 3:41:25 PM(UTC)
ajb1010
110.62922100
Simon / APP Team
#4 Posted : Monday, May 21, 2012 5:58:27 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Check the thermal cut-off and hi limit thermostat located on the side of the heater box. If one of them is open - replace
the kit Part number: 279769
Part number: 279769
Clean all air ducts from lint before using it.
Thank you. Post the results.
Simon.
ajb1010
#5 Posted : Tuesday, May 22, 2012 5:15:43 AM(UTC)
ajb1010
I actually already replaced both of those, and the element and cleaned the duct. When i replaced the thermal cut-off and thermostat it worked for a day and now does not heat again.. Could I have wired it incorrectly? I misspoke when I said i replaced the fuse, I meant the thermal cut-off and stat.
Simon / APP Team
#6 Posted: : Tuesday, May 22, 2012 12:30:58 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
First check if there is 240VAC to the dryer.
Then check all the thermostats, fuse,including the one you have replaced for continuity taking one wire off the contact.
See if there is 240V at the heating element contacts(only if you fill comfortable doing "life" test).
If no 240v - trace the leg witch has no power.
In the case of opened thermostat make sure there no blockage in the vents.
Simon.
Kenmore Dryer Will Not Heat After Replacing Everything (Dryer Repair)
by jlewis57 10/1/2014 12:28:50 PM(UTC)
Kenmore Dryer will not heat but the drum runs (Dryer Repair)
by asirota1 3/25/2013 8:33:52 AM(UTC)
Kenmore dryer will not heat (Dryer Repair)
by cfalter 9/29/2012 4:34:50 PM(UTC)
Kenmore dryer will not heat on second cycle (Dryer Repair)
by Jim G42 7/15/2012 12:18:17 PM(UTC)
by saw3c 5/18/2010 9:48:06 AM(UTC)
Kenmore Dryer Will Not Heat Up (Dryer Repair)
by mastaone 11/8/2009 12:44:09 PM(UTC)
by vikingboy 9/25/2009 1:04:15 PM(UTC)
Kenmore dryer will not heat.3 weeks-- my wife is mad (Dryer Repair)
by topagent 7/31/2009 12:51:43 PM(UTC)
by lpennock 5/10/2009 3:56:08 PM(UTC)
Kenmore Dryer will not heat (Dryer Repair)
by T.A.M. 2/9/2009 5:29:54 PM(UTC)
